solli5pack
- Joined
- Jun 17, 2023
- Posts
- 504
- Reaction score
- 775
In GM’s schematics and breakout diagrams for purchasing parts, what is the component they list as the BCM?
I had one go bad on my 03 Impala and the horn would randomly start blasting and not turn off.In GM’s schematics and breakout diagrams for purchasing parts, what is the component they list as the BCM?
you connect a obd splitter to monitor via the 2nd Y portThere's different types of glade plug-ins that 'disable' V4 mode, by somehow tricking the ecm into thinking that one or more of the conditions that would prevent V4 mode happens to be in effect.
The plug-in that tricks the TCM into 5speed mode would cost some MpGs.
Not sure that's the most clever way of avoiding V4 mode, long-term.
What IS clever about those plug-ins, is that while the plug-in is plugged in,
How does one get any realtime ecm / tcm data? How does one look at what the plug-in is actually doing?
(petethepug, V4 mode is tuned out of the ENGINE control module, not the body control module, even if other modules can say something to the engine control module to prevent V4 mode.)
Years ago I blocked off the oil pressure relief in the oil pan, because the spring in it was failing. That increased the oil pressure and gave a more consistant pressure. The afm worked up until this issue. So, pretty sure this - along with 3000 oil and filter changes - contributed to the longevity.352k with AFM is better than a lot without AFM lol impressive!
BCM: body control moduleIn GM’s schematics and breakout diagrams for purchasing parts, what is the component they list as the BCM?
I'll open it.I also run Quaker State full synthetic ultimate durability dexos 1 gen 3 - the one with the gold label.
It's the best on the market - but that's a serious pandora's box that I will leave closed ...
Im pretty sure my 2007 Tahoe LMG, vin0, engine cam broke (or cam chain broke?). Just shut off on highway, threw a code P0340. Removed cam sensor, stuck my finger in, rotated the engine by hand, and couldn't feel or see the reluctor wheel spinning. Verified by looking down the oil fill, rocker arms not moving.
So, with 352000 miles - completely stock - AFM operational until this - I am pulling the motor.
I plan on deleting the AFM, and installing the proper kit too do so - cam, block off plate, lifters, ecm delete, etc. etc.
Question I have - IF the engine I have cannot be used, what years can I use to replace the one in my 07 Tahoe?
Is there any 5.3s that do not have the AFM/DOD setup that will work?
The cam sensor is in the front cover, and the knock sensors are on the side of the block (easy accessed).
I am not looking for any type of performance upgrades (other than the afm delete) or larger displacement - just a job that can be easily done - because its getting cold and I'm doing this on the street lol.
Thanks for any help
Depends on how you drive it, and whether or not the ecm & tcm are reprogrammed properly to provide increased line pressure to hold the 4L60E together.Dropping in a 6.0L or 6.2L to have a plug-and-play (or near it) upgrade would be fun, but you gotta consider the transmission.
It's adequate behind the LMG, but will be stressed behind the HP/TQ of an upgraded engine.
@petethepug Gotcha, I have a mechanically AFM deleted 5.3 that has AFM tuned out with a Black Bear tune. Just wondering if I got bored enough if I could drop a 6.0 in or if I needed to do anything else.The AFM software that is usually sold as a AFM defeat or disabler can simply trick the trans from going into overdrive keeping the AFM from turning on. All the troublesome mechanicals are still in the motor so if you’re referring to tuned off, its really not.
You’d have to have a tuner write a program to tune it out. That’d be far easier than using the 6.0L BCM and adding all the existing trucks features to the donor motor profile. After the AFM is tuned out of the BCM, then you need the 6.0L motor that never had AFM or the existing 5.7L motor with all its AFM mechanicals removed.
Never said to detune the 6.0L.... why swap in 50 (at least) more HP/TQ, just to throttle and / or tune it down to worn 5.3L power levels?
I was basing my comment on GM's advertised ratings for the 4L60E, which, in this case would only apply if his had been rebuilt to proper OEM specs.
Cranking up the line pressure is only a small and specific solution. That damned sun shell still has its limit.
With how I run mine, I'm convinced my trans has been rebuilt or replaced. Or I'm just still lucky for the time being.
I've often thought if our 2007 6.2 L92 gave up I'd find a 2010-2014 4.8 L20 to replace it. We have no need for the L92 power and would like to run 87 octane with its lower compression.Im pretty sure my 2007 Tahoe LMG, vin0, engine cam broke (or cam chain broke?). Just shut off on highway, threw a code P0340. Removed cam sensor, stuck my finger in, rotated the engine by hand, and couldn't feel or see the reluctor wheel spinning. Verified by looking down the oil fill, rocker arms not moving.
Thanks for any help
Between cranking up the line pressures, carefully editing the shift strategy tables, and not being a leadfooted riceboi, the only things left to worry about are:
if that 4L60E has not been rebuilt in the last 5 years (NOT 50), and/or if the axle gears are 3.42 or less.
I was kinda wondering the same after looking around due to this thread and OP's question.I've often thought if our 2007 6.2 L92 gave up I'd find a 2010-2014 4.8 L20 to replace it. We have no need for the L92 power and would like to run 87 octane with its lower compression.
L20 doesn't have AFM, does have VVT(good), is FlexFuel compatible(good), and an iron block(good).
I think we could plug & play this swap with a tune, and keep our existing exhaust, wire harness, ecm, tcm, bcm, 6L80, etc.
If power was lacking I'd install a turbo kit.
https://www.onallcylinders.com/2018...ormance-bore-stroke-cylinder-heads-cam-specs/
4.8L is like a 5.3L from 3500RpM to 5500RpM. Under 3500RpM, it's even weaker - more like a 4.3L V6.I've often thought if our 2007 6.2L L92 gave up I'd find a 2010-2014 4.8L L20 to replace it.
L20 doesn't have AFM, does have VVT (good), is FlexFuel compatible (good), and an iron block (good).
