the_tool_man
Upstate South Carolina
I broke the defroster connector today. Knowing this is a frequent failure, I avoid opening the glass. And when I do open it, I don't let it swing all the way. It broke anyway, while the glass was closed.
RooTBeeRthe1st
I had my rear glass replaced like 6 months ago, by safelite, partially because the stock one had that issue, and also it was scratched pretty bad.
Within a month or two, the new Safelite glass did the same exact thing and I only opened it once or twice. But it popped off while it was sitting there closed, and I had not even turned on the defroster once.
KraftMatic87
I knocked out several projects in the past few days on my 2009 Yukon XL Denali.
- Replaced passenger side CV axle
- Replaced rear brake rotors and pads (PowerStop Z23 rotors with ceramic pads)
- Replaced starter
Next projects :
- Air ride delete / New front and rear shocks and struts
- Replace fuel pump / sending unit and all fuel lines
The beast is running real good! Going up to Grand Lake for Christmas this weekend with the family and I'll probably hit 150k on the odometer while I'm up there! Currently at 149,500!
Not sure how good it works, but I've seen people warm up the coiled wire with a hair dryer (or more carefully with a heat gun) and stretch it out a bit while the wire is warm. Hold until it cools, and it should stay a bit stretched. That should take some of the tension off the connections.
Frostfighter FTW.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Mine fell off too. I did the rear frost, and wiper arm delete. and double 5% tint. Rear squirter still good for attacks.
Charlie207
LFOD, New Hampshire
My rear defroster stopped working last year. Neither of the connectors popped off, but it just doesn't get any heat. I've swapped the relay with a known good one, but still....
It would be nice to have.
RooTBeeRthe1st
Coincidentally enough, my rear wiper worked on the way home yesterday, and won't work at all this morning. Wonderful
mikez71
Silly Ford guys, don't they know they can open the rear doors and ride in the back seat?
I want an A-pillar grab bar even more now..
Looking at the photos, the roof rack they are holding onto looks like it may extend partially over the camper...
possibly to provide grip for someone standing in the rear position.
curbud
