alpha_omega
Michigan
Anyone with new battery suggestions? Im going to replace the original on my father in-laws 2020 Denali (everything is OEM), but I wasnt sure who to go with this time. Delco from the stealership is prob going to cost a fortune compared to even the local AP store “gold”. But ive also heard that even the optima (which used to be good), are no longer what they used to be.
Any thoughts or suggestions?
*special note. I forgot that the RPO codes are no longer in the glovebox on newer vehicles. It’s a QR code found on the lower part of the drivers B pillar near the running board. Scan the code and it will populate a link with the codes.
alpha_omega
Michigan
Different strokes for different folks. Nice to know there's a nice shiny AAA truck within 30 mins from anywhere in the USA though, that's worth the annual fee.
I wish that were the case. We called AAA when a tire blew out on our horse trailer. Despite being on a main 4-lane highway they told us 1-2hours. I was able to get it changed out even with a horse onboard before they called us back with an update (telling us it would be closer the two hour mark). That weekend I dropped AAA after and bought four brand new Carlisle’s for the trailer.
It would have been nice if they showed up, because my wife and her family don’t keep any tools in the trailer before then. Nor did they have any flares or even a set of triangles. That eye opening experience changed their thoughts on that subject really quickly.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
New brake calipers, rotors and pads on the ‘07. Tried to install new brake hoses too, but the ones I bought from Advance Auto had the wrong key pattern around the collars on the inboard ends so they wouldn’t fit into the mounting brackets. See pic. So I went to autozone and asked for the correct brake hoses and they had the same problem too. I could look at them side by side with the factory parts and see the different pattern clearly. Weird.
How did you do the bleed?
Geotrash
Dave
Richmond, VA
By the way, here's what the rotors I took off looked like on the inboard sides. Both were worn in a similar pattern, which I attribute to worn calipers. Looking at the inside edges of the new rotors after a few days' driving, they're wearing much more evenly so far. The new ones are Powerstop Z23 rotors and pads.
I had installed them back in December, 2018 so they had 5 years and about 45K miles on them. They only saw road salt 3-4 times since then, and I hit the car wash immediately after each time, so they were rusted more than I expected. This is what they were:
j91z28d1
rock auto had a good price on acdelco agm batteries. mine wasn't agm stock but they don't sell or ship the normal ones. so no core return either.
the agm vs normal lead acid is a deep rabbit hole. but I tried it and so far so good. only been a year or so thou.
costco: interstate regular or AGM, I am suprised the Interstate AGM's I bought I have (3) of them all 3 are still good after 3 years in cali heat, usually that's tittz up time for battery's around here, The Odyssy's I have been buying previously have all died at or just before 3 years, years ago they used to last at least 4 years they must have changed something.
The Interstates cost almost 50% less than the Odyssy's, they usually run $300 the Interstates were $160'ish from Costco
RooTBeeRthe1st
Got my ACDelco AGM's from amazon... Seemed legit, both had the same build? date and were fresh.
I had previously gotten an optima yellow top to add to my original GM battery, then when the original battery died, I ran two yellow tops.
And then the first yellow top died right around 4 or 5 years old.
So this time around I actually decided to put that one year old optima back in my second battery position and get a new GM/ac Delco agm to put back in the primary position.
$350 + for an optima that only lasts 5 years tops now doesn't make much sense to me when the GM battery was half the price or less and lasted just about as long.
I'm still going to keep one deep cycle battery though, when I go out shooting or camping or whatever, I disconnect the starting battery and just run things off of the deep cycle and obviously it won't get hurt if I run it really low, then I can swap back to the main battery to start it and recharge the secondary.
Buford bubba
