The KidWagon
KidWgn
KidWgn
Certified Kid Hauler
St. Louis, MO
I just came here to say, “FORK this free travel mod”.
What a pain in the absolute ass. I got one side done today, and the Spohn kit installed. I’ll knock out the other side in the morning!
Doug118
I can’t imagine how big of a pain it is on a Tahoe. I had my buddy who’s much more precise with a grinder cut mine and I was on stand-by with many fire extinguishers
KidWgn
KidWgn
St. Louis, MO
Pics dammit
After cutting and a flap disk:
After paint and Spohn UCA
KidWgn
KidWgn
St. Louis, MO
I knew you had pics! You called my bluff. Good job! Daytona jack FTW. Homer bucket FTW. Damn that thing is clean. Now the rotors REALLY look like chit. >wink<
That’s why I paid what I did for this one. It’s SUPER clean. I actually just took those pics when I posted them, just for you :cheers:
I freakin love this low-profile long-reach. Worth every penny.
That, sir, is a Harbor Freight bucket
I KNOW, OKAY :boxed:
randeez
south florida
I’m late to the reply but for purposes already stated. I always thought it was just for wheel clearance. Didn’t know about not being able to adjust them
i dont think i really spun the entire bar either tbh, but i back that heim joint out a few turns so i wasnt making all of the adjustment with the threaded rod coupler side
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Well you did right attacking the driver's side "free travel mod" first. That's the worst side, other side should be easier from what I have read.
KidWgn
KidWgn
St. Louis, MO
The driver side was exponentially more difficult than the passenger side, because of the damn gas tank. I got around it by using a 40” pry bar and a 7” cutoff disk, but it was still a bear trying to not cut into the tank. I still nicked it with the cutoff wheel, you can probably see it if you zoom in.
KidWgn
KidWgn
St. Louis, MO
I did the same; I adjusted it so that each section was in its “middle” when seated currently. I’ll finish adjusting tomorrow, and I have another alignment scheduled for Tuesday morning for the front control arms.
This is mostly how I did mine. 4" death disc on the outer wall and front and back side walls. Then a recip saw reaching through the front cut slot to cut the back wall as far as I could go. Then pried it down with a wrecking bar to score the back wall from the inside-out. Worked it back and forth a few times to break it off. Cleaned it with a flap disc.
KidWgn
KidWgn
St. Louis, MO
Yup! 4” diamond cutting wheel for the outboard and sides, then sliced it up the middle. Used a 40” pry bar to pull the whole thing down then switched to a 7” diamond cutting wheel and let ‘er eat!
KidWgn
KidWgn
St. Louis, MO
Here I was in the middle of cutting. You can see where I chopped it up the center to allow it to bend downward.
brice715
