I have a police horn and the controller, some day I want to hook it up and just use the police horn/buzz function (not the siren), not trying to perpetrate lol
the speaker is heavy as hell. I figured I can stick the controller behind the center console and solder a wire to the horn function and put a button in the cubby on the dash that is vacant where the 4wd switch would normally go
I wouldn't have had time to use it today anyway I was lucky we didn't rub shoulders
Whelen? 315 speaker is 100 watts, the SAK24 plate is made for our grills to mount it and the PAP112 is the air horn with handset.
PG01
Up here to the right
Snapped a pic last night…937pm est
CMoore711
That’s the factory waxy ******** coating from GM. Mine peeled off in chunks…. Terrible…. Just terrible….. lol
It looks like the factory coating and I know how it peels off in chunks.
So how is his still there looks so good and intact still?
@gooffeyguy
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Yup that is the "air horn" function for that particular sound.
89Suburban
SE PA
had to use a different browser it doesn't show the video's on amazon business, that sound is closer to what the whelen sounds like
There was a good buyer review I saw for it but I am having trouble finding it.
Onenicedenali
Been slowly doing some upgrades to the '13 ESV since that has now become my daily.
Did the diode mod in the fuse box so my DRL's stay on with my low beams and illuminate the entire headlight housing.
I've got 5000K LEDs in the DRL and parking light up top, and my OSRAM CBB HID bulbs are closer to 6K.
In the first pic you can see the difference in the light color, but in the last 2 they look closer to matching.
Contemplating swapping the parking and DRL LEDs out for 6K due to my OCD.
(I know my fogs are still stock halogens, that's changing soon...)
Can you please explain the “DRLdiode mode” in more depth?
PG01
What do you think of them?
To be honest paw paw, I’m not so much of a ‘I need bright headlights kinda guy’ but these are pretty bright right out of the box, I guess you can get some good bulbs and make them better, and being that I never ‘aimed’ them correctly they are a little high and light up everything on low beam high beams are even better. Every once in a while I get flashed but I’ll flash the highs so they know im not purposefully being an a-hole. I really got them just to change it up back then. 5 years later and they held up pretty good although the ds is starting to get that ‘clear coat peel’ look in the top corner because that truck sits in the sun nowadays…since buying the yuk the tahoe was banished from the garage ….. I put the sunshade in the windshield since it does sit in the sun and hopefully I can keep my dashboard from cracking…. Which brings me to getting that airbag recall done…. I really don’t want to bring it in because I don’t want the fools at the dealership to fugg up the dash….I wish they would just give me the airbag so I could do it myself….I guess i should get it done tho since my daughter has been cruising it around….
89Suburban
SE PA
I'm wondering how they would look on mine with the push bar.
Drewphil
