iboughtatahoe23
- Joined
- Feb 17, 2023
- Posts
- 663
- Reaction score
- 365
Thanks for the replies.Replacing the lines is a lot more work but not complicated, tedious. You have to drop the front axle down on the passenger side and remove the lower shock bolts to get some clearance to get the lines through.
Depends on whether or not you have the external transmission cooler.
That's a step in the right direction. It ought to come down some more as you drive it. If it stays high but drives fine, then that's the computer adjusting for a tired throttle body.
I don’t have a Jack so maybe the cooler lines might be something for the shop?
