This is my sports car not a ghetto mobile lol
Sports CAR??This is my sports car not a ghetto mobile lol
Of course! That's why I suggested black duct tape. It'll blend in and work juuuuuust fiiiiine.
200mph duct tape. Hell yaa, it hits 140+ that's sporty enough for meSports CAR??
200mph duct tape.
I've noticed that Wes will sometimes plow through thigh-deep water, so on his a snorkel might be too short.How long does the vent tube need to be, and where does it vent to?
Hell, on both mustangs and the street rod, there's no vent "hose", just a little 1" tall covered nipple thingy on the top side of one of the axle tubes.
Hell yaa, it hits 140+ that's sporty enough for me![]()
Especially if you already have everything else apart and replaced a bunch of other things, men's will do it now, preventative maintenance.Alright here goes…I’m in a bit of a dilemma. While I have the front end removed and the 40k unhooked, should I just bite the bullet and replace the radiator now?
While I’ve never had any heat issues, I am at 96k miles (6.2l) so time is ticking for the radiator. These are usually what a 150-200k replacement if they don’t get clogged or fail before that timeframe?
I replaced the water pump and all the hoses, fittings, clamps as well as the oil cooler lines, power steering lines and the pump. If I am replacing the radiator, do I need to replace anything else while I’m in there - mounts, clips, support frame…etc?
I know over in the tru-cool thread we all recently discussed which Rad is better versus which is easier to “plug and play” without extra dissection of the supports, but I can’t remember if we discussed any of the other replacement items. I’m sure someone (or many) has at one point or another in this thread.
So…whatcha got for me? Do it while it’s in pieces and before it’s too late?
Thanks…
I wasn't denying the sporty part, the car part is what got me. The first s and SUV stands for sport lolHell yaa, it hits 140+ that's sporty enough for me![]()
No need to replace the core supports and the new radiator should include them anyway in case yours are rotted out, but I doubt it. And if you buy a direct-fit OEM radiator, you won't have to mess with adding any restrictions to the bypass tube, etc. But I would replace the coolant tees at the firewall if you haven't already, along with the heater hoses and wye, since you didn't specifically mention those. The correct one for the Yukon Denali that will match the original in core thickness is this one: https://www.summitracing.com/parts/dnp-221-9514 Note that Denso is the OEM manufacturer for GM also.Alright here goes…I’m in a bit of a dilemma. While I have the front end removed and the 40k unhooked, should I just bite the bullet and replace the radiator now?
Thanks…
Awesome. Thanks. I am debating between Mishimoto and OEM, just for the simplicity of not having to monkey with cutting anything. I figure if I need the restrictor (as per the TSB), I will just cut it off my old one.No need to replace the core supports and the new radiator should include them anyway in case yours are rotted out, but I doubt it. And if you buy a direct-fit OEM radiator, you won't have to mess with adding any restrictions to the bypass tube, etc. But I would replace the coolant tees at the firewall if you haven't already, along with the heater hoses and wye, since you didn't specifically mention those. The correct one for the Yukon Denali that will match the original in core thickness is this one: https://www.summitracing.com/parts/dnp-221-9514 Note that Denso is the OEM manufacturer for GM also.
Nearly all of the others listed as fitting it on sites like RockAuto, Autozone, etc actually have a thinner than OEM 1" core. But I measured my core when I replaced the one in my '07 and it's 1.3" thick.
I didn’t realize they were 1.3”, which is odd because the Mishimoto is listed as having only a 1” thick core.Nearly all of the others listed as fitting it on sites like RockAuto, Autozone, etc actually have a thinner than OEM 1" core. But I measured my core when I replaced the one in my '07 and it's 1.3" thick.
I just pretend mine is something fast by driving around in m3View attachment 400024View attachment 400025
We ran out of road in a 45mph zone yesterday, so I didn’t quite make it to 140.
I’m still happy with the fact I sold that car, but do not like the newer Denali's enough to buy one and have it sent to Hennessy. I’ll send my 2011 before I send a new one.
sounds good with the borla, lol and nice throttle responseLet those RPM’s roar!
With 3.08 gears, M3 is pretty zippy. At 70.I just pretend mine is something fast by driving around in m3![]()
