AFM Lifter Failure Average Mileage?
tdebacker
Hey everyone, I'm wanting to install a full DOD delete and cam from Texas Speed & Performance before the lifters go out, but I need to know when can I expect the lifters to fail?
My 2017 Suburban 5.3 is sitting at ~85k miles right now and I'm wanting to save up for a full camshaft/DOD delete kit/reseal before it gives me issues.
I do a lot of highway driving so I rack up the miles fairly fast. I've already put 20k miles on it since I bought it in late September, with another 5k planned by the end of May, so I'll be well over 100k in a year or so.
I use Amsoil Signature Series 0w-20 and the matching Amsoil oil filter along with oil change intervals usually between 7500 and 8500 miles.
Thanks in advance!
pa31p
It’s like the lottery. nobody knows.
could be at 25 miles could be 75000 miles or never or more than once. a full delete will remove the lottery part and being proactive could save you some money.
On a 2017 you have some options.
Marky Dissod
FYI, I was a livery driver in NY / NJ / CT / PA, although over half of the miles were accrued in Manhattan.
The vehicle in question was a 2012 GMC Yukon XL with a flex-fuel 5.3L V8.
In an attempt to improve city MpG, I had a tuner INCREASE the V4 duty cycle.
V4 mode was made available whenever the road speed went over 21MpH.
I put over 185K miles on that Yukon XL in roughly five years.
Oil consumption became a problem, usually had to add 2 quarts between every oil change.
The lifters never failed, likely because the motor oil was changed 8x a year.
The additional oil consumption hints (to me) that the rings of the colder V4 cylinders wore the bores slightly.
Since it was a lease, I can't say I regret taking even more advantage of V4 mode than GM originally intended.
Had I intended to keep that vehicle, allowing ANY V4 mode enablement would have been a mistake.
RST Dana
OH
How did you not get robbed by the excess mileage as a Livery driver?
Marky Dissod
Even if your plan is to wait until just before the V4 components fail, it'd be wise to DISABLE V4 mode NOW.
That will delay the failure of the V4 mode stuff because it will never go into V4 mode.
I firmly believe - even though my Yukon XL spent far more time than GM intended - that the lifters did not fail because I changed the oil 8x a year.
The other thing I'd do is decide between a 3.23 and a 3.42 axle, and install that upgrade at first convenience.
Yes this requires a tune for best results.
The tune and the axle gear upgrade are among the best mods possible for any vehicle, especially these big suvs.
tdebacker
tdebacker
I'm
I'm soon going to get a tune from Blackbear to disable the AFM and recalibrate for the 33s I'm about to install. I have the factory towing package so it has 3.42 from the factory. With 33s I almost debate putting in 3.73s since I'm wanting to tow, but I do a lot of highway miles with just people in my Burb so I'll keep the 3.42s for now
The reason I gotta save up is because I'm wanting to do an engine-out refresh with the full cam, head gaskets, head bolts, springs, lifters, etc when I do the delete. Later on I'd also like to have the trans removed and have a better torque converter installed since the 6L80s have that issue, too.
Marky Dissod
With 33s I almost debate putting in 3.73 since I'm wanting to tow, but I do a lot of highway miles with just people in my Burb so I'll keep 3.42 for now
If the highway miles are mostly flat ground, stick with 3.42, despite the 33" tires.
If the highway miles are mostly uphill & or downhill, I'd personally advise 3.73.
tom3
From what I've read when the motor is in the 4 cyl. mode those four cylinders are pulling their guts out at time. Much like an actual full throttle mode. I suspect this is what causes some of the oil consumption after some mileage. Could be why some people complain about the engine vibrations with this system. I do like the mileage increase and the technology is pretty awesome, but those gizmo based lifters scare me too.
Marky Dissod
The dormant cylinders are supposed to be acting like air springs.
Those cylinders are thus subject to greater thermal variations, more often than the always active cylinders.
If you let V4 mode cool the dormant cylinders for too long, ask Chrysler what happens.
GM never pushed it that far, but the 4 sometimes-dormant cylinders wear themselves down at faster rates compared to the always-active cylinders.
My guess is that's how the increased oil consumption occurs over time.
But whether it's the lazy cylinders or the overtime cylinders that will progressively consume more oil, point is, use of V4 mode increases oil consumption, even if the V4 lifters never fail.
And the design of the V4 mode lifters is more likely to be outlasted by the V8 mode lifters.
However the V4 mode lifters' weakness can be minimized / delayed by disabling V4 mode in the software.
Most of us would gladly lose several MpGs if the gain was spending less money to maintain / fix a powertrain that will also last longer by avoiding or minimizing its weaknesses.
(If you need MpG that badly, then have your spark maps custom-optimized for 91 octane, and very seriously consider 3.23, 3.42, or 3.73 to take a bit of load off of the powertrain.)
RST Dana
OH
Don't think I understand the question. Please rephrase?
As a livery driver your mileage should have well exceeded the lease amount and usually cost additional dollars at the end of the lease. In the neighborhood of $.25 per mile.
Marky Dissod
I was permitted to 'buy' the truck out of the lease before it exceeded the allotted mileage.
I was making quite a bit over $0.25 cents a mile until about 2018, when I gave up on livery driving, and sold the truck. I came out ahead, at least in terms of money anyway.
TollKeeper
Brighton, CO
Usually thats the case, unless you purchase it at the end of the lease.
BG1988
the issue is hypercycling of the v4 mode... it's most likely because of sludge build up from lack of oil changes that causes the failure i thought mine was failing but it's just an exhaust leak you can really smell it on startup outside of the SUV
I get P0420/430 in the winter time ..i'm going to start running AFM again because of gas prices 26-28mpg is better then getting 23
Marky Dissod
... most likely because of sludge build up from lack of oil changes that causes the failure (of V4 mode lifters) ...
1. I changed my oil more than often enough.
Superior oil filtration capable of screening finer particles would also be helpful.
I actually think one has to change the oil so often, because oil filters are not quite good enough at their job.
Unfortunately, oil filters are not more precisely rated (which also keeps them from improving).
Using an oversize filter might be of some help.
Using an oil filter better capable of filtering out unusually finer particles would also help protect the V4 lifters from their weakness.
2. My experience with 'overuse' of V4 mode leads me to surmise that the 'sometimes' cylinders change temperature by enough to wear down their rings and cylinder linings at a faster rate than the 'always' cylinders.
In effect, the 'sometimes' cylinders age more rapidly.
What I'm saying is, instead of simply reactivating V4 mode to its previous settings, it may be wise to alter those settings, so as to keep the 'sometimes' cylinders from getting as cold as GM's original settings allow.
Your mileage may vary.
40Rouge
I recently had the AFM concern at 76k miles. I've been driving for a while now in "L9" mode to keep the engine in v8, but I recently purchased a Range AFM disabler so I don't have to keep doing the L9 hack. The Yukon feels so much better in constant v8.
For anyone that doesn't know, putting it in L9 drive will keep the car from shutting down cylinders. It's a "hack" to get around AFM. Plenty of Youtube videos on it.
Marky Dissod
Disabling V4 mode will increase the lifespan of the V4 lifters; by how much is not possible to predict, but the sooner the better.
Obviously DELETING V4 mode hardware / replacing with proper V8 hardware (including proper V8 tuning) is the best course of action to take in the long run.
LANCISTUL
I agree. My 2012 Suburban is a fine example of this. Bought it at 130k, immediatly disabled AFM via software, now I'm at 350k (yes you read right) original engine untouched. I had the tranny rebuilt at 260k, and thats it, that's the only big service. Starts every morning, no issues. 5.3 LC9
a1parrothead
