Lifted/Leveled 2021 - Postem Up
ProfeZZor X
High Country
What’s the offset on those?? That’s a good looking Yukon. What’s kind of rubbing and trimming did you need to do?
The offset on my 24x14's are -76. I knew what I was getting into a couple of years ago before I even ordered these wheels. I just didn't like the "flush" look on current gen Yukon/Tahoes, and wanted to do something different. I did have to cut away some of the wheel well closer to the bottom, but otherwise, it turns just fine.
The only thing I'm waiting for now is for my current tread to wear down so I can upgrade my tires to 35's. I should have done it the first time around, but I found myself listening to too many haters and decided to play it safe by getting 33's.
A10MileHusker
Beaverton, OR
I'm not sure the specifics of your ride (I have a 22 Yukon AT4 w/ Magnaride) and I missed the memo that you need the Magnaride relocation bracket. So I just ordered that and now delayed another week until that arrives.
Just wanted to give a heads up to you and anyone who might be considering this.
No you dont. At least not with my wifes ‘22 high country.
Post pics of the bracket…links…or whatever it is. I couldnt even find it when i installed the kit on hers.
To update this, Went to install my Motofab 1" level lift on my 22 and confirmed I did NOT need the bracket that Motofab said I did.
But do love the 1". Leveled my AT4 perfectly.
H1Chester
Your AT4 should have come level from the factory. My 2022 Z71 did. Rear wheel well is only .25” higher than the front on stock non air ride.
A10MileHusker
Beaverton, OR
I can't keep it all straight. I talked with another company who said the same thing, your AT4 is already lifted and lifting more will cause more stress on CVs.
But there was no way mine was.
H1Chester
@A10MileHusker i honestly didn’t believe it at first. Last year I read a post on a thread on this forum that said that the Z71’s come from factory already level. I went out to my driveway and checked myself. I only have a quarter inch of “rake”. I would have to dig for the thread (maybe earlier on this very thread) but a few other members chimed in saying they measured their stock rigs and same, only about .25” difference. The people who put a front level on their rig were puzzled that the front was now slightly higher than the rear… So yes you can lift your truck but a front level on a 21+ Z71 = “Carolina Squat”.
Nokturnal
3.5 RC
Amp steps
20x9 Fuel Quakes (+1mm)
35x12.5x20 BFG KO2
Chrome delete (minus front Chevy and rear bow tie)
Painted tow hooks and skid plate
Debadge
5% Ceramic Tint
Nokturnal
More pics
Nokturnal
Fenders trimmed and one more of powder coated Quake. Zero rub.
Nokturnal
Didn’t realize how easy it is to pop off bow ties with interior trim tool! Black out complete front and back.
Hunter Linn
Tuscaloosa, Alabama
So I finally got my RC 3.5” lift on yesterday afternoon with 35x12.5 Venom RT tires (I know I will get push back for these but I got them at a steal) and Bora 1.5” spacers on front (they only had 2 in stock yesterday) the rear spacers will be sent to my house next week and I will put them on then. Here’s one photo. I will get more this weekend.
Hunter Linn
Tuscaloosa, Alabama
It does sit level but the photo was taken on a slanted parking spot
nick14226
Looks great!
Definitely looks taller than my 2” on 33’s
Nokturnal
My math has that at a -10 offset for those guys looking at wheels with -12, -18 offsets.
+28 mm - 38mm (1.5”) = -10mm
nick14226
Keep in mind the stock wheels are 9" wide though, most aftermarket wheels with those offsets are 10" wide which changes inner clearance and outer position.
Trailzrider
SoCal
I ended up going #kingshocks, 285/75-17 #toyotmt #methodracewheels #mazzulaoffoad UCA's #amppowerboards I need to re-valve the kings for rutted fire roads. I will try front 10/10-Flutter-17/17 and rear 10/10-Flutter-15/15 I did have to do some triming for the front. Once I can afford to do LT right I will see what #lsk has to offer.
d_hawk
A little off topic from shock valving…. I notice you have added an aftermarket recovery point to the front of your Tahoe. Could you post some closeup pictures, manufacturer and part number for the shackle setup and any installation notes you might have?
I have a high country suburban (same non Z71 bumper setup as you) and have wanted to add a front recovery point, the Z71 recovery hooks bolt up but don’t have bumper clearance to be useful.
koomie98
