+18 vs +30 wheel offsets
henryr
hey guys. i have a 07 4x4 tahoe with the stock 17's. looking to go to 18's.
looking at a set of xd hoss in 18x9. they have 5.71 bs and come in either a +18 or + 30mm offset. 285-60-18 tires.
i have dealers telling me different things on whether the +18 will stock out past the fender wheels. apparently, +30mm is backorder forever.
anyone have any pics to see the difference ?
tirerack list the new dick cepek torques as a fitment - but according to DC - these will stick out also....
need some help finding a wheel that fits. also like the ATX crawl.
thx
Modded
That Guy
I have 295 width tires with a 20mm offset wheel and the front tires stick out 1/2", the rear ones don't stick out at all.
With a 285 and 18mm offset, your rear will not stick out, while the fronts will less than 1/2".
H
henryr
have any side pics ?
i've done a search on the internet. hard to find any pics of nnbs tahoes with anything smaller that 22's.
macky
i have +18 offset, with 295s rear looks perfect the front sticks out a little more than i would like it to, but looks good. only rubbing is when wheel is fully turned to the left.
2 E L O
Omaha, NE
It's not so cut and dry... The issue with offset is useless unless you include the wheel width.
So, a few notes:
The stock 17s are 7.5" wide.
The 18"x9" XD Hoss wheels in +18 or +30 cannot both have 5.71" backspacing. The different offset would mean that the back spacing is different. The +30 have the 5.71" bs, the +18 would have a back spacing of approximately 5.21".
Modded and macky, what width are your wheels? The offset is irrelevant unless we know the wheel width.
H
henryr
So, a few notes:
thanx for the explanation.
i'm looking at getting the dick cepek torques. 18x8.5" +20mm offset and 5.59 BS. tirerack says they will not stick out and DC says they will.......going with 285/60/18 tires.
this truck is a PITA to find aftermarket wheels for that i like.
Modded
That Guy
2ELO my width is 10", and Henry I have 24s.
I do know the stock 20" wheels are a +31 offset on a 275 tire and 8.5" wide wheel.
2 E L O
Omaha, NE
Their calculation seems to be a bit off for the backspacing.... 20mm=0.79", 4.25" (half the rim width), so 4.25+0.79=5.04".
I'm not sure where they're getting 5.59"..... That would be closer to approximately +34mm offset.
Anyway, if those Torques truly are +20mm offset, they will stick out about 3/4" more than the OEM wheels.
If the 5.59" bs is correct and they're approximately +34mm offset, then they'll probably only stick out about 1/8" more than the OEM wheels.
Hope this helps!
H
henryr
those specs were from the tirerack website
DC's website shows
18x8.5 BS 5.5 and +20mm offset
what is the distance from the stock 17" to fender wheels ?
H
henryr
from a website calculator :
shows DCs with a 285-60 tire stick out .8" farther and .4" farther with a 265-65 tire. either of those big enough to matter ?
Lubbock,TX
I feel your pain with wheel searching... One of the reasons I went with a set of takeoff factory 22's...I knew they wouldn't "stick out" like a roller skate!
H
henryr
you'd think with as many GM nnbs trucks it wouldnt be such a PITA
dizhai
