2003 Chevy Tahoe- Transmission Fluid Change
rockola1971
Indiana (formerly IL)
lyncht1967
I bought one of these pumps:
https://www.amazon.com/Wekster-Mult...=1678557442&sprefix=auto+fluid+,aps,96&sr=8-8
Went to home depot ad got about 6' of tubing (either 1/4" or 3/8" cant' remember) inserted it into a short piece of the red hose I cut and ducktaped. red hose on pump, tubing down the fill pipe. Sucked out all it will do (about 4 quarts) refilled. Drove around ten minutes. Did this 3 times. Figured I got to about 85% new fluid. Trans loved it..so smooth.
I know dropping pan and changing filter would be optimal but I have always had no trouble with trans and kinda regular changes so don't expect filter to be bad off.
Took and hour and didn't even get dirty. I was amazed how efficient it was. Will always do trans this way...
tomloans
https://www.amazon.com/Wekster-Multi-Purpose-Transfer-Dipstick-Extractor/dp/B076TMQGMN/ref=sr_1_8?crid=ZDXB9M70AX1M&keywords=auto+fluid+extractor+pump&qid=1678557442&sprefix=auto+fluid+,aps,96&sr=8-8
If it works, why not!? With mine, (provided you are not going to change the filter) it is as simple as a bolt in the bottom of the pan. Easy to get to . Unbolt, drain put bolt back in and refill. Do you not have a bolt on the bottom of your transmission pan? Is this why you thought of this?
dougo
Raleigh
I have a vacuum pump works great suck it out pour it in easy
YukonRog
Auburn, CA
Too late now, but If you pulled the pan and changed the filter you'd be able to see how dirty/clogged up it was. I was able to get my deep pan off my '04 Yukon without loosening the D Side exhaust. Just the P Side. Pry bar to press the pipe over is all it took. And removal of the linkage to avoid damaging it. You'd really be surprised at what the filter catches. It's a good indicator of what's going on inside. Maybe next time...
BC
My 08, the downpipe nuts are pretty hard to get at with the cats in the way, i just took the hangers off the exhaust and let it drop down a bit and a pry bar and gave lots of room to get the pan off cleanly.
easymoney
You must just have bad luck or you overheated the camaro's tranny therefore overheated the shift solenoids. In all the 4L60E's that I've owned and still own, I have never had a shift solenoid fail. Do you replace your ignition coils because they have 150k miles on them? A shift solenoid will last alot longer than a belt or hose will.
I have had 2 tahoes , a 99 and currently have a 2004. Both had solenoid issues. Never over heated that i know of but there is no guage who knows. I rarely tow anything, i changes the fluid and it atill happens. My dad has a 02 silverado and the sunshell broke on it at around 100k but no solenoid issues Its common for this to happen. I replaced the transmission on my 99 at about 150k. The 2004 got 105k on the first then at 200k the rebuilt one crapped out. I had them put in the gm remanufactured one so hopefully it lasts more than a 100k since its supposed to have fixed the factory defects that gm refused to update. I still like my tahoe even though it has had many issues.
lyncht1967
I did, but it's aluminum and someone had already rounded it..even got nut extractor set and it was just welded in there..all extractor did was chew it up more
GMT800 2005 Tahoe Z71
Navy Supporting Member
@rockola1971, since I have the step pan I never wondered till now. What is the reason for the two pans and two filters? If have the shallow pan, can the deep pan and deep filter be changed over and if so, what would be the benefit, if any?
nonickatall
Germany
That's just speculation, but if the later models have the pan with the step, they probably changed that because when there are large inclines, acceleration or braking, the oil is more secure in the pan and can be sucked in by the pump. With the flat oil pan, it can of course happen that the oil pump draws air in such situations.
MassHoe04
Western MA
If trail riding, a deep pan might not help ground clearance over obstacles if it hangs lower than a stock pan.
When I had my Jeep, everyone in that forum was all about "tummy tucks" raising engine mounts and lifting engine and transmissions as high as possible to gain ground more clearance.
I would guess deeper pan, holding more fluid, would allow greater heat dissipation. I would think more cooling would be good for heavy duty towing or really launching it on a drag strip.
I am willing to learn, if I am wrong on this. I am not pretending to be a transmission/performance build expert.
nonickatall
Germany
Beim Trailfahren hilft eine tiefe Pfanne möglicherweise nicht, die Bodenfreiheit über Hindernisse zu überwinden, wenn sie niedriger als eine Standardpfanne hängt.
Als ich meinen Jeep hatte, drehte sich in diesem Forum alles um "Bauchdeckenstraffungen", um Motorlager anzuheben und Motor und Getriebe so hoch wie möglich anzuheben, um mehr Bodenfreiheit zu gewinnen.
Ich würde vermuten, dass eine tiefere Pfanne, die mehr Flüssigkeit enthält, eine größere Wärmeableitung ermöglichen würde. Ich würde denken, dass mehr Kühlung gut für schweres Abschleppen oder wirkliches Starten auf einem Schleppstreifen wäre.
Ich bin bereit zu lernen, wenn ich hier falsch liege. Ich gebe nicht vor, ein Experte für Getriebe/Leistungsaufbau zu sein.
More volume can also be a reason... The question is which oil pan has have the newer models. If the flat oilpan is at the newer models, it can all so be that you are right and they want to have more space to the ground and as well produce a cheaper oilpan, because for the flat one you need less material and and you have a simpler cast...
NickTransmissions
Sin City
The transmission bench
The later, deep pan and filter design can be installed onto any 93-97 4L60e and provides an additional 3/4 of a quart or so. All other things equal, the more fluid you have for cooling, the better.
nonickatall
Germany
The later, deep pan and filter design can be installed onto any 93-97 4L60e and provides an additional 3/4 of a quart or so. All other things equal, the most fluid you have for cooling, the better.
Then it's probably about more oil, bigger filter and less risk to suck air in certain situations.
But, The deeper pan can be added to a shallow pan set up and the bigger/deeper filter would just plug right in?
NickTransmissions
Sin City
Yes. You need the late, deeper filter with the deeper pan to reach the bottom of the pan. There is a very slight designed interference fit between pan and filter so the pan can hold/retain the filter in the pump. Otherwise it would just come loose and drop part way or all the way off.
I figured that but was wanting to be sure about the filter mount area where it plugs in. I have a friend that may do this changeover.
Ossipeelake
