Lifter tick help will mmo or motor flush help?
T
Trey Hardy
Looks like you got yourself a good old fashioned rear main seal leak there sonny. Along with possibly an oil sender,valve cover gaskets, and whatever can give up at 325k. LOL
I'd probably address the driveshaft sooner than later. I know they slide in quite a bit to make up for suspension travel, etc. But seeing your suspension is always traveling......away, you'll probably want more contact on the output shaft splines before they cease to exist.
Just cleaned up the valve covers the best I could I’ve ruled them out I believe it’s the oil sender possibly a pan gasket but more then likely the rear main seal leak I’ve had since I got it. That’s not getting fixed until I go to do a transmission or rebuild the motor
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
View attachment 392759View attachment 392760View attachment 392761
Not horrible but still want to trace it out if possible
Also my yoke has been like this ever since lifting it im assuming I would need a longer yoke or extended driveshaft? Not problems so far but figured I’d get y’all’s opinions
Got new u joints I have to make the time to install
Welcome to the RM seal club. I have been chasing down oil leaks on this old girl since I bought it. Seems like every time I replace a gasket another old one blows out form the high mileage and crankcase pressure from blowby. I have 4WD so no way am I going to lay on my back to pull the trans and install a new RMS. Getting to old for that S.
Which means I would have to pay somebody a few grand to do it. I can't justify that expense for an engine getting ready to hit 350K.
T
Trey Hardy
Same here! If i threw that kind of money into it I would be swapping in a 6.0-6.2 from the scrapyard
j91z28d1
I'm just going to throw this out there for the guys with super gunked up engines, first thing I'd do is turn off the afm. they basically need perfect oil to keep from galling up inside and sticking. it pretty must always happens, but more often with dirty or long run oil.
2nd there's an old trick and it seems to work, lots of youtube on it. where you drain some oil and add atf in it. then run it at idle for an hour or so to wash down what you can. my only add on to that is these oil filters bypass at 12psi. once the filter media restrict more than that it lets dirty oil by. while this is happening pretty much always a little bit besides maybe idle with a fresh filter (gm recently changed to a 22psi spring for newer engines lt based engines) wix has a filter without a bypass. it's 57026, you'll probably have to order it, it's mostly for industrial stuff, but it fits the ls based engines and is longer. pick one up and spin that on before doing the atf flush. just don't drive it or rev it hard. it's burst is like 250psi, so that's not a worry, just filling it up with junk and not having enough oil for the engine would be the only thing to watch for, but that said, if you do see the oil get low, that's a filter full of crap you just kept from dragging thru your bearings.
I've found that this guy's YouTube is a wealth of knowledge for lifter afm stuff, and he's got a message board to ask questions on. I've done his afm bypass, and I think it's well thought out and caught early, I expect it to last just as long as a full delete without needing to take the engine apart. just the intake
St. Louis
The oil filter bypass pressure rating is a differential of pressure between before and after the filter media
The Wix 57060 which is the cross reference for the OE ACDelco PF48 for our trucks has a 12psi bypass
The Wix WL10255 (cross reference for ACDelco PF63 which is a longer version for our trucks) has a 22psi bypass
Also, the Mobil M1-212, K&N HP2011, and Wix 57045 which are longer filters that fit our trucks all have a 12-15psi bypass
robgreg75
My 2010 collapsed a lifter at 278k miles, I pulled the head and replaced the lifter but it had damaged the cam so a lesser knock but still a knock after replaced. 280K now so 2k miles on the knock and it isn't getting louder. I know it isn't an exhaust leak since I can pull the rockers off that cylinder and no more knock.
T
Trey Hardy
Did you check your pushrods and all also?
Dustin Jackson
If I’m not mistaken I thought you had to switch cam shafts and valley covers with you do a dod/afm delete?
This is true, the story rob greg tells sounds like he didn't delete AFM or replace his cam it sounds like he just replaced the lifter and put it back together
T
Trey Hardy
Right
And the lifter damaged the cam lobe
Luckily when my valve spring broke it diddnt damage the cam
However it bent a pushrod, broke the valve spring, dropped/bent a valve, and cracked the head.
The lifter was scarred up a lil so I replaced it
Dustin Jackson
@Trey Hardy That's a crazy amount of damage. I always recommend to crack the motor open before jumping to conclusions and so you can make an accurate replacement parts list. Imagine you bought replacement cam and lifters to find your head and valves all messed up too
T
Trey Hardy
I got new lifters
Brian tooley sent a top end rebuild kit with pushrods valve springs retainers head bolts etc
Cam was undamaged and lifter weren’t bad but diddnt want to reuse it by no means
Heads were on my own dime that was another 200$ for some 899s and 400$ for a valve job and some porting
T
Trey Hardy
Buffed it out and sent it
robgreg75
@robgreg75 Did you keep AFM and use the same cam?
@Trey Hardy When I did mine the pushrods looked good but I still replaced them
I have not replaced the cam yet. I am waiting for my home to be finished that will have a much larger garage. I will just put it back factory. If it lasted 278K miles before I am not worried about the AFM.
T
Trey Hardy
Just an update the marvel mystery oil is still working well for me!
Haven’t had a stuck lifter since last year! My Tahoe is now creeping over 350,000 miles on the stock dod lifters and cam
Oil pressures holding strong
May have the occasional cold start lifter chatter for the first couple seconds that goes away pretty quickly.
I believe without the marvel mystery oil I would’ve tore the engine up long before now as I’ve got two lifters un stuck in two difference scenarios.
briannorris
