Are you talking to the plug wire or the Exhaust manifold.....
Oh, my bad..... #8 spark plug. I changed the post, thought I started it that way.Are you talking to the plug wire or the Exhaust manifold.....
Thats why I had dealer do my plugs and wires. I did the airshocks and air pump myself but wanted to save my back so dealer for plugs.Oh, my bad..... #8 spark plug. I changed the post, thought I started it that way.
I get it if you have a bad back, it can contort you in weird ways.
Overall not too bad, there was adequate room but tight. Was a number of different small extension combinations for the full process.
View attachment 393713 The stool positioned in this manner really makes a big difference with a firm footing.
Use AC plugs or NGK. Do not use Bosch, the LS engines don't like them.I guess I better get ready to do my plugs. They have 132k on them.![]()
Will do buckaroo.Use AC plugs or NGK. Do not use Bosch, the LS engines don't like them.
Let’s see those black badges!Put the black badges on this morning, changed the front brakes this afternoon.
I want a set of quickjacks so bad!!Oil and filter change. Did it in the driveway and put it up on the QuickJack so I could also roll round under it and spray parts of the underside with Surface Shield. I'm surprised that all the new control arms and tie rods are already getting that powdery light brown rust coating on them. It's only been about 4 months.
I had my daughter climb up in it to reset the OLM and take the obligatory picture
SameI want a set of quickjacks so bad!!
I'd prefer a lift, or even one of those MaxJax, but I didn't want something that had to be used in the same spot all the time. I have too many vehicles to have to move around to use it. With this I can use it wherever, anywhere in the garage or driveway.I want a set of quickjacks so bad!!
