- Joined
- May 15, 2021
- Posts
- 551
- Reaction score
- 1,366
Hello All,
I am ordering parts for replacing the torque converter and doing some internal upgrades to the 6L80 in my 140,3** mile 2013 Escalade ESV. As such, I have talked myself into pulling the intake manifold as part of the job. To have the fuel injectors cleaned, replace gaskets, and for better access to the top bell housing bolts.
However...I have fallen down a rabbit hole for the scope of this job:
With the intake off, I should check the torque on the VLOM bolts.
Well...shouldn't I proactively replace the VLOM gasket? I can't find a listing for the gasket. I found a listing for the non-AFM VLOM. However photos of the AFM VLOM and non-AFM VLOM show the gaskets seem different. So maybe I shouldn't worry about replacing the gasket.
Since the intake is off, might as well do the valve cover gaskets...
Sooooo...should I try to replace the VLOM gasket? I know I should be doing an AFM delete, but I don't feel like opening the front of the engine to pull the cam. I already have AFM turned off in the Black Bear Tune.
As well, are there any "gotcha's" for pulling the intake manifold? I have been searching here on TYF, but have not seen any hard details.
Thanks for any and all advice!
