Onlyone
New Mexico
OK Thanks.. I looked at the diff ones from RA too... I saw the CAPA certified ones a while ago. Mine aren't too bad, yet
Yeah these are the CAPA ones but I can’t tell a difference. Not sure one is any better than the others. Mine were much worse in person than on a picture. The LED lights were the highlight of the upgrade. So much more light.
Charlie207
LFOD, New Hampshire
Dropped in a new 160A alternator and serpentine belt. Old squeaks & squeals are gone .
Old
Uck..
New
I also spent 30 mins with the engine running trying to find the coolant leak. You can see the wet spot in the top left, along the hood seal.
The front of the engine is dry, nothing around the water pump or any hoses that I could see/feel, and the heater core hoses & plastic connectors are bone dry.
The hunt continues ...
Foggy
KS
Old
Uck..
New
IF you are losing coolant in that area, it's for sure the heater hose Tee's...
Get the GM ones, not dorman or other brand.. Kind of a PIA to change, but you'll be
stranded and overheat your engine once they "go"
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Old
Uck..
New
Dang bro you got leaks everywhere. Valve cover gasket? Brake master cylinder? What the hell is all that fluid all over the driver's side strut tower??
tungsten
Where's that setting?
Mine will only run for 10 minutes and shut off, and you can only do that cycle twice without having to cycle the key.
In the infotainment.was on 10min It says to change setting hit the check mark?? Then it switches to “on” but doesn’t change when you hit the check mark again? Did a little googling and can’t find it. Now the remote start won’t work??
89Suburban
SE PA
What does it say in your owners manual?
Foggy
KS
I don't do pics and all that young person stuff cause my smartphone is really dumb....
But I did replace my Pass Rear Outside Door Handle Today (before the snow hits tomorrow)
I had to replace the front pass side door handle in the spring.... The first owner
must have had little dumbass kids pulling on them all the time (my grandkids do
this to their parents' cars)... I don't play that shit, homie !!!
RooTBeeRthe1st
Ah, got ya. Mine has no infotainment.
Finally put the "Trans Dyno Tune" on.
Now locking the converter and locking in a gear works perfect.
Had to test it of course. Cut the runs short due to traffic(wasn't an issue before since I always used 2nd).
BLUE line was an on ramp with an incline.
Seems like those numbers probably aren't too far off though.
tungsten
Alright so after you hit the check mark press and hold. It comes up “on selected “ now remote start works. Yay cause it’s -28 outside.
Glad you figured it out. I was gonna say you must have turned it off because you can't increase the run time without a BCM tune or an Autosync.
Charlie207
LFOD, New Hampshire
It's not the tees. Everything up there at the actual connections is dry. It's looking like when the fans turn on they are spraying the leak up that way.
All hoses are dry at their connetions. Next step is to rip apart the front end, and check the radiator I just replaced.
Denaliz
Frisco,TX
One more wheel and I’ll have a complete set:oops:. Some how there’s a missing wheel in my order
Damn these guys ship with a quickness. Vossen’s say by Tuesday. Now to call TSP and get them moving along too
One more wheel and I’ll have a complete set:confused:. Some how there’s a missing wheel in my order
Escalade2007
