Engine and Tranny Issues - Update in OP
rustycrocker
I have a 2007 Yukon XL with 160k miles. There are two issues:
Tranny hard shifts from 1-2. I replaced the 1-2 accumulator with a Sonnax pinless accumulator. It decreased the frequency of the hard shift, but it is still happening about 40% of the time. When I replaced the piston, there was only the small spring, the large spring was not installed. Ever seen this? I am considering replacing the Sonnax with the GM OEM accumulator, as it lasted 150k with no issues.
The engine (LMG 5.3 Flex) has a very rough idle, but cleans up around 1500 RPM. There are two codes showing:
P0449 (EEC vent valve solenoid). I replaced the solenoid with with no improvement. Clear the code and it comes back.
P0308 (Cyl 8 misfire). I suspect this is the AFM (Chevy shake).
Anyone care to comment?
TIA
Update 1/2/2023
Cleaned MAF with no improvement. Checked MAF with code reader and 5-6 on idle and 20-23 on acceleration. Pretty close to specs, so MAF is OK. Changed plugs and plug wires. BAM!! No more shudder, tranny shifts great. Looks like that was the issue.
Still have one code, P0499 - Evap Cannister Purge Solenoid. I have replaced the solenoid with no improvement. Maybe the PCM or the wiring?
Dustin Jackson
With a transmission that old it might just be worn and due for a rebuild, I wouldn't bother throwing parts at it just drive it until it stops driving and then rebuild it.
I don't think cylinder 8 is an AFM cylinder, I think 1,4,6,7 are the AFM ones
Dustin Jackson
@rustycrocker It's totally possible a non-AFM cylinder had a lifter failure. The lifters are just held in with plastic trays. To save money you can tear the engine down yourself to find the problem.
R
rustycrocker
My intention is to replace the more inexpensive components on the Yukon (plugs, wires, coil and injector) and see what happens. Worst case, I will do a teardown, as my warranty has long been expired.
I just wanted to get a second opinion.
TIA
Ever cleaned the MAF sensor?
Just Fishing
Can't fix stupid
Utah
If you have a filter like a K&N, make sure this is part of your normal routine
It really only applies to when you over oil the filter, however I usually just clean my filter.
Clean the MAF.
Run it for a week, then clean the MAF again for good measure.
I have a K&N for my Tahoe, but I haven't installed it yet. :jester:
And if you do get one, make sure you buy it for a 6.2
Same filter dimensions, but the 6.2 has more and deeper pleats than the one for the 5.3 (For some strange reason).
jackal78
