raptor liner instead of paint ?.?.?.?
dojrs
I've been contemplating raptor lining my 2005 Tahoe instead of painting it. Biggest reason being I cant find a paint and body person local to me that will do an all over paint job. Has anyone on here done it yet ? It seems like a fairly simple process, biggest thing is time, I work with a paint and body guy but even he doesn't know anyone within a 50-75 mile radius who will do an all over paint job. The more I've looked at it the fonder I've come to it. He told me to sand mine with 180 grit, do my body work, then sand with 220, clean, then spray it. light coats multiple times until desired thickness. I'm thinking either all over grey or either FDE and coyote tan. need some help on ideas and paint schemes from yall. im not opposed to using stencils for a more personalized look
D
dojrs
Well, owning a 2005 Z71, I have thought about a wrap before and even a lower 1/3 liner painting. No more wax jobs. Different look. Wears like iron and easy touch up.
definitely tougher than typical paint, my only apprehension is if i can get it close to a similar gloss shine as a regular paint job. I'm guessing if it were to be clear coated to have a shine to it the clear coat wouldn't hold up as long.
adventurenali92
Big Bear Lake, ca
Raptor liner is not going to shine and be glossy like normal paint. It’s not designed that way.
I will say this…..
keep in mind that if you go this route and for whatever reason don’t like it or there’s major blemishes that need to be fixed in the lining, removing it will be a major pain in the ass. I bought a bumper cover off a junkyard truck that was coated in similar lining and I thought I could just have a shop remove it and then I’d paint the bumper. Every body shop has told me basically the lining isn’t coming off and even if they could get it off the surfaces would all still be rough and un even and painting with regular paint wouldn’t be an option.
MassHoe04
Western MA
If the body is pristine, I would say go for it. If there are any rust issues, you'll want to be sure all traces of rust are treated or completely removed.
The liner material is the perfect cover for rust to progress and you would never see it from the outside. If the rust has perforated, the coating could trap moisture and accelerate the rust-out.
I continue to be on the fence on lining an entire vehicle... Looks cool and durable for sure. But I would be afraid of not seeing where rust is eating away at things, having it look great from the outside, only to have it rotting away. Maybe that would not happen, but it is a fear I would have on doing this kind of thing.
Just my personal opinion here... Nobody is locked into agreeing with me on this at all.
tungsten
Typically You would do this knowing theirs rust issues and the life of the truck is coming to an end anyway say like 5-7 ish years.I was going to do mine for a quick fix but decided to go with paint instead.
Im in a salt area, Ive seen plenty of lined trucks.Does seem to last,some I swear have added 200lbs of it lol.
D
dojrs
If you like a contrast look, go for it. Plus, post pics so I can see if I want to do it.
will definitely post pics of it after it's done. gonna wait until it's warmer weather so it gets a good bond. the weather doesnt get really cold here, however in the next month or so the winter rains will start and I'm rotating back to night shift in the next week for 12 weeks. it'll probably get done mid march or april of '23.
As far as contrast goes it's the factory pewter/grey color now. im thinking I'll stick with the pewter maybe a little darker grey and do a large warrior helmet on the hood, dont know exactly yet. havent put pen to paper yet. i want it to be different but suddle. I'm not trying to go too wild as its still a DD at this point.
My hood is already peeling with the dreaded chevrolet paint disease. If I stay with my factory hood I know I'll have to sand the entire hood and roof to get it right. I've thought about the HD hood swap for a while now and they're hella hard to find used, however I did find the aftermarket HD hood that Summit Racing carries. Has anyone tried it or seen it ? I dont wanna waste $500+ on a thin flimsy sheet metal hood that wont last, but I wouldn't think Summit would offer sub-par materials. If anyone wants to donate ideas on a paint scheme I'd be open to ideas. black and grey seems to be the colors most rolling through my brain.
tungsten
Now there's two kinds of liner,box is the ruff rock hard stuff.The other is more rubbery.Which is the Raptor?
J-KTM
In my opinion,
I have also considered this for my truck and my Yukon. I live in a area that uses salt, sand and chemicals to keep ice off the road. That means if you drive in the winter here your truck is doomed no matter how clean you keep it. I agree that when I see a vehicle that had this done and it can make me think they are just covering up rust. Having said that you could properly prep it, sand it down and still raptor line it. You would just have less finish work for raptor liner as opposed to painting. You can get the raptor liner tinted with your color and the kits come with proper spray guns. Check out some guys on you tube that have done it. I have thought about it for sure. Sure if you use a brush or roller and hack it up the body it will look like garbage. Also I have heard comments about added weight. I really think this is a non-issue. It has a heavy look for sure but if you consider the weight of a can of paint to the weight of a can of raptor liner the difference is minor. It's definately not for everyone but I think if done properly, it is a great way to go.
thingraylinetah
Crossville Tennessee
My raptor lined 06 tahoe
Sam Harris
I think it can look good, but has to be done right. I figure a lot of folks expect it to cover up imperfections, and expect it to look good without proper preparation, and I’m sure we’ve all seen the horrible, and permanent results of that theory.
Personally, I’d only do it on a dedicated trail rig type vehicle, not a daily. But that’s just my opinion. I think it’s the perfect solution for trails, where you don’t have to worry about tree branches skinning your paint, etc.. I’m also curious.. it seems to me that it would be a lot harder to actually get clean, once you have dug in the mud, etc.., due to the non-slippery / polished surface. Just seems like it would hold onto dirt a lot more than regular paint, but I’m not speaking from experience here.
thingraylinetah
Well,
A regular repaint was 4 grand quoted by the two shops that do it around here. Spent 850 got it raptor lined with 3 coats of the liner. It was sanded and prepped then sprayed. Mine was done right. We live out in the boonies, there is alot of mud when it rains, lots of trees, and snowy roads in winter. I just wanted a tough as nails finish and that's what I got. To each his own. I love it. It's not hard to clean really no more so that anything else I've cleaned.
Another cool feature is that you can mix whatever color paint with it and once you get the desired color you're looking for then you can spray it on. I really considered od green or the tan that the Toyota Tacomas are now like flat dark earth color but settled on charcoal Grey color.
JasonW4141
