Oil ?
tekfire07
Quick question the dealer I purchased my Tahoe from did a oil change before my purchase. I noticed they put 0W-20 oil in. Do I need to replace it with 5W-30 asap or can I wait until the next oil change?
GMT800 2005 Tahoe Z71
Navy Supporting Member
What are the temperature ranges in your area? This time of year, you should be fine with no worries. What does the oil fill cap call for and what does your owner's manual say?
B-train
I do concur with above statements. However, I have seen 1 instance in my career where a sudden change to thin oil not specified for a certain motor caused damage (early 90's grand prix 3.1L).
That being said, if your oil pressure looks good and the engine sounds normal you're probably good to go. Just monitor oil consumption on that year motor, especially with thinner oil.
As far as increased mpg benefit, it's negligible at best. Maybe 0.2 - 0.3 mpg better, and usually just on warm up. If you're the person who jumps in at 20F and hits the road as soon as you have rpm, then you might save a little bit. If you are like any caring, educated driver, then the brief warm up in cold weather pretty much negates what the EPA was trying to accomplish in their 'conservation' efforts. LOL!
There's a reason why any work truck that has a similar architecture motor runs 5w-30 instead of 0w-20. Different C.A.F.E regulations.......and longevity
Foggy
KS
I personally would NOT be happy with a place that can't read !!!
If you are in a cold climate you'd be fine...
But I'd still want the correct weight and grade in my engine
This is exactly why when buying a 'new to you' vehicle you go thru every
system and fluids and filters.. Then you have a real starting point for all future
maint and repairs.
When I bought my Yukon a few years ago (used) I'm pretty sure it had the
wrong oil in it. So I changed it the day I got home even though they had just
did a service on it (they said)... they used a cheap ass oil filter so I assume they
used whatever was cheapest in bulk oil they had extra of...
maint and repairs.
I looked under my neighbors F150 the other day for an oil leak. He has only been to Jiffy Lube and the dealer for oil changes since he bought the truck in 2006. The whole under area was dry except for one place. It actually had oil drip on the drain plug and what looked like to be 3M Weatherstrip Sealant squeezing out under the head of the drain plug. I put a wrench on it and tightened as much as I dared, about 1/8" turn and stopped. I believe the oil pan threads are stretched. I am going to do an oil change this weekend and I have already gotten a new drain plug and seal for it. He had every invoice for everything thing that has been done and it only mentions the "oil leak" 2 times on the Jiffy Lube tickets but none on the dealer tickets. He has been seeing the oil for the last 3 years, drops on the ground and adding as needed. Someone saw it and should have brought to his attention but is trying to hide with the "Gorilla Snot" around the drain plug. Two pics. A before and after I wiped dry and tightened and you can still see the oil seep at the lower area and soon to be a drop. I told him the same thing. I don't trust anyone but myself for any fluids when buying and always change them all to get a base to start from.
donjetman
Just Fishing
Can't fix stupid
Utah
If I were to try a thinner oil, I would for sure cut the oil filter open after running it for a little while to see the contents.
(The oil filter opening/cutting tool can be found on ebay and amazon pretty cheap)
I would also say take a bright flashlight to look for any sparkles from the oil that's draining from that filter.
If it looks good, and you don't notice any extra noise coming from the engine then I would say it's probably fine.
Just to be clear here. The "0" viscosity has to do with the lubrication capabilities at colder temps and the ability, if needed, for it to flow at lower temps to help lube at start up and warm up. It then changes to the "20" viscosity to lube at higher ambient and engine temps. If in an area that is higher temps then the "30" viscosity is available and that seems to be, especially with synthetics, the norm nowadays. It is very rare for a viscosity of "40" to be called for. Engine builders and designers want that oil to FLOW for better lube and protection.
If I messed any of that up, please correct me. Also, engine oil requirements and certifications are very important and must be met and of course, use a damn good oil filter.
Dustin Jackson
There is someone here that runs 0w-20 oil but they do it by choice. If someone else put that in my motor without me asking for it I would not be happy.
wjburken
Eastern Iowa
When you say you "noticed" is that because that is what was on the service ticket or did you see them put the 0W-20 into your vehicle?
I would take it back to the dealer and ask them to change the oil. There is a chance the technician or service manager is so used to dealing with the newer vehicles, which I believe now take 0W-20 and just wrote 0W-20 into the system for the service ticket record, but actually put 5W-30 into the vehicle.
Foggy
KS
I know some have experimented with lighter oils...
but the oil doesn't just lubricate your rotating parts ...
IT'S vital to the VVT systems, DOD systems, etc...
Those systems are specifically designed for a certain weight oil as they are hydraulically actuated.
Lot's of issues when ford started using 5w20 and all the shops were still putting in 5w30...
It F'ed up a lot of cam phasers, etc destroying lots of new motors
ZKWBQD
Yes, the sewing machine oil (0W-20) will probably give you 0.01 MPG better. You've probably disabled it, but you can add another 0.001 MPG for engine Stop - Start. This is being pushed by the EPA. For longer engine life many believe 5 or 10W - 30 is better. The problem is, many dealers simply will not do it. I've had trouble (perhaps a run of bad luck) of using oil change places on my vehicles. Growing up in Detroit, I was brainwashed to change my oil at 500 miles on a new vehicle, and then every 3000 miles after that.
01dailey
I won't EVER go to a quick lube......I'll change it in the walmart parking lot if I absolutely have to! Anything goes there.....
The last time I went to a quick lube they underfilled it. I checked the oil level when I got home and it was 2 quarts low. The oil didn't even reach the dip stick. In a prior incident following an oil change, the oil filter came loose and I had a massive oil leak. These quick lube places can't be trusted. They hire cheap low skilled labor and rely on insurance to cover their mishaps. The dealer is the only one I allow to touch my vehicle.
rbromm
Quick question the dealer I purchased my Tahoe from did an oil change before my purchase. I noticed they put 0W-20 oil in. Do I need to replace it with 5W-30 asap or can I wait until the next oil change?
What is the problem with 0W-20? I run Amsoil 5W-20 and no issues with mine. 65,000 miles and not burning or using oil. I did add a catch can and get about 1/2 pint in it every 5,000 miles. Thinner oil flows better and this engine is clearanced to run fine on 0-20.
HughW
Drewphil
