Tips and Tricks on getting manifold bolts off of Y-Pipe
m1dn
Hey folks, looking for any tips, tricks and suggestions on getting Manifold Bolts off of Y-Pipe :)
Bolts on mine decided to become one with nuts
I tried a little penetrating oil and only have medium impact ( ~500lb breakaway torq ), no luck, doesn't budge.
Right now looking around to see if any specialized shops have a rental high-torque impacts and see if i can break this ***** loose.
Was also going to try longer wrench, hammer and doing it by hand, but i'm worried about making the nut round.
The space is so tight i'm not sure i could get an angle cutter there to get it out as well.
wjburken
Eastern Iowa
Might see if you can get some heat on it.
Also, I’ve had some luck with rusted bolts alternating between trying to loosen it and trying to tighten it in short bursts while putting some penetrating oil on it in between. My preference is aero Kroil.
If you put a nut busting high torque impact on it and just go to town, you’ll likely end up with a rounded nut, not desirable, or a broken bolt.
M
m1dn
Thanks, will try to play around with propane torch and see if i can fit in there without melting o2 sensor wires ( and if do, i'll just replace it )
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
My suggestion is to use an oxy-acetylene torch to heat the nut. If you can clean the threads of the stud first it will help. Be careful! You might snap that stud with too much torque.
B-train
I agree with the oxy acetylene torch, but Mapp gas is a good second. You need to get them glowing red and goes easy with a ratchet first, and impact will just make a mess of it if they don't fit perfectly.
You can also heat the stuf where it mounts in the manifold and try to back out the whole deal and just put in all new hardware. They key though is HOT. Another old trick for that is getting it hot and then melting a candle onto it. The heat will draw in the wax like solder to copper. Sometimes it helps to free up the threads.
Drewphil
