Tonyrodz's Tahoe Build Thread
To reset the long term fuel trims, connect the Tech 2 and enter your vehicle information, and go into the Powertrain menu.
> Special Functions
> Fuel System
> Fuel Trim Reset. It collects some data for a few seconds.
On the next screen the fuel trims are shown, and a soft menu item "Reset" at the bottom of the screen should appear. In order to select it, press the soft key (just below the screen) once -- or you might need to do it a second time -- and the LTFTs should reset to zero. (Since the engine is not running, the STFTs are static at 0.)
Thanks @Fless. I'll try it tomorrow. I'm pretty sure I did what you described and it didn't work for me, but I'll give it a shot again. Does it need to be running or does the vehicle need to be key on, engine off?
I don't know if you can do it while running, but it should work with just KOEOff.
You see my E85 LTFTs, right? Pretty much perfect...
I'll quote my dad: "No time like the present!"
As usual, gonna be a bit before I can get to it. Bringing the stinkin' home to a mechanic this Saturday. I'm hopeful he'll find the issue. He's actually the only guy I'd call a mechanic and not a parts swapper.
Gonna go look at a car this Sunday. I'm hoping it'll work out. It's an 05 GXP. I've always liked them--plus we need another car, instead of the 2 junkers we have now.
Took it to the mechanic today, he checked some basic things. Does anyone have any recommendations on a good 6" cone filter? I'd rather it be the dry style. The one in my Volant is so filthy, can't even see through it, plus the rubber on the neck is starting to crack. He also told me he thinks the maf is too close to the box(mounted on it), and too far away from the tb to get a good correct reading to send to the pcm. I've had a soft maf code since the original 6.0/cam swap was done. He thinks it being mounted on the cold air box might be part of the issue. Told me to get a new filter, and to clean the maf really good. If those aren't the problems it may be the pcm has a bad board in it. This kind of makes sense to me. The original tuner told me he couldn't program the pcm in the truck, that it kept losing communication with his laptop. This happens to me all the time. Constantly loses communication with the Tech 2 AND with my scanner. One time I had gotten a bunch of crazy random codes when I plugged in my scanner. So--try cleaning the maf, get a new cone filter, and if that doesn't solve the problem, a new pcm.
So........anyone know of a good 6" dry cone air filter?
97YukonNZ
Hey :D
I am still running a stock airbox in mine but when i changed my airfilter out i replaced it with a K&N serviceable cone filter. Has been really good.
This is how it is set up. Just had a look,needs a clean.
Thanks for the reminder. Air is important. Will be great if thats fixs your issue.
Cheers
Hey :D
I am still running a stock airbox in mine but when i changed my airfilter out i replaced it with a K&N serviceable cone filter. Has been really good.View attachment 377894This is how it is set up. Just had a look,needs a clean.
Cheers
Thanks. I'd really like to stay with a dry filter. Way too many stories about issues with the oiled filters. I really think it's gonna come down to replacing the pcm unfortunately.
97YukonNZ
Can you just chuck in a cheap replacement paper filter,clean the maf and see what that does for you?
Although reading through your thread again the pcm could well be a contributing factor.
No air though is gonna cause shit down the system anyway.
I guess I could, but I'm sure for a few dollars more I could get a good/decent one.
Took a long ride today, and it didn't run that great. Took the mechanic's advice and cleaned the maf, and also cleaned the air filter--for now. I'm probably gonna buy a cheapie but figured I try and clean it 1st. Couldn't even see through the filter it was so dirty. Gf is driving it tomorrow, so I guess we'll see if it helped. Pretty sure it'll need a pcm too.
Bentley95
