04 Silverado started knocking, what could it be? Rebuild started
ivin74
05 NBS Nali
Htown, Texas
The truck is my son's 2004 silverado extended cab. He has it cam'ed out, headers, tune and other misc stuff including a high perf transmission. The truck is not his daily. This afternoon he took it for a drive and got on it hard. After a couple of runs he heard some knocking. I would like to hear from the experience folks what you all think broke.
He is going to get it towed to my house tomorrow, probably will start by removing the heads and inspect the top end.
Donal
Americus Georgia
Remove spark plugs, take compression reading and record for all cylinders. That will identyfy the cylinder with a problem. Remove valve cover for the bad cylinder and check valve train. Repair as needed.
Sounds like a exhaust valve is not opening.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I am with everyone on this. Is the normal oil pressure still there? I doubt it. Sounds like also has an exhaust leak at the manifold but may not with all that noise. Remove covers and get a look see and whatever you do, fix it right and don't band aid it.
Please report back here about what you find out. Compression test as well before removing cover(s). Make sure all plugs are out and remove fuel injection relay when you do the compression test.
One last thing: There is a low down knock noise that I feel sounds like a rod knock as well as the upper end tick noises. So, like @rockola1971 said, I would have that in the back of my mind when diagnosing this.
ivin74
ivin74
05 NBS Nali
Htown, Texas
My first impression was a bent push rod, still waiting for my son to get it tow to my house to give it a proper diagnosis.
Hard to tell from video. Could be a bearing, did oil pressure fall off? Could be in the valve train. First thing is to find out if the noise is high or low. Almost sounds like collapsed lifter I had a few years back.
You are right it sounds like a collapsed lifter but this truck does not have the AFM system.
Snowbound
Jim
Chicagoland (Lockport)
First thing I would do is check oil for any glitter on stick. Assuming it hasn’t gotten any worse, start it up and see if you can pin point if the noise is high or low or what side it’s coming from and see what oil pressure is. If it’s higher up on engine, pull valve cover or covers and look for play in rockers. It could be a bad lifter roller and/or cam lobe. They are more prone to flaking cam lobes than they are spitting a bearing.
rockola1971
Indiana (formerly IL)
The problem with theories of the sound being a collapsed lifter is if you listen closely to the knocking you will hear a slap after the knock. It isnt every time but it is a prominent sound. That knock slap routine ive only ever heard from a rod knocking.
"This afternoon he took it for a drive and got on it hard."
I take this to mean he was getting hard in the throttle and revving it. Which is when a rod bearing will decide to spin.
corvette744
2004 Z-71
Northern illinois
Def has a exhaust leak but also sound like a rod knock.Should be able to put it in gear and give it some gas under load and it should be very loud.Even revving it you should be able to tell if its down low.Also when you turn it off most rods will knock as they stop that have spun.
MassHoe04
Western MA
Just to clarify... rod, meaning valve push rod or rod, meaning piston connecting rod?
I think you were talking about push rods, but I was getting muddled in the conversation.
I wouldn't want to assume...
Thanks.
ivin74
ivin74
05 NBS Nali
Htown, Texas
@Snowbound.
You almost nailed it. The truck has a stuck lifter and it messed up the push rod
ivin74
ivin74
05 NBS Nali
Htown, Texas
From what can tell the stuck lifter did not open the valves and too much fuel was been traped in the cylinder causing the head turn black
ivin74
ivin74
05 NBS Nali
Htown, Texas
After I got it out, I removed the drivers head and found some of the lifter shattered pieces. Next weekend I'm going to remove the oil pan & tray to see if I can find the remaining pieces.
ivin74
ivin74
05 NBS Nali
Htown, Texas
After a close examination of the cam thru the lifter hole, I could see the damage done to the cam. The damage keeps getting worst. I'm starting to think the builder (Velocity parts & performance) used the wrong springs and created float on the lifters during high revs.
TejasPitt
