Stubborn Harmonic Balancer
Plimbob
Des Moines Iowa
I have been in the process of removal of the cam sensor which has been a failure - detailed in other thread.
Now I have resorted to removal of the timing cover, I have everything off around it and have removed the balancer bolt. Now stuck with a stuck
harmonic balancer. I am using an OEM three jaw puller which connects and hold on flawlessly.
The problem is that baby is like it is welded on (engine has 306K and it's never been off), I have heated it up let it cool and heated it again but its not budging. I put a pretty good amount of pressure on it which resulted in starting to bend the extension push rod.
I have done some research and have seen different hacks on here and Youtube, using a socket instead of the rod, using the old bolt with the flange ground down and screwed back into the crank (that makes me nervous about damaging the threads?) and then using an air impact?
Anyone have any thoughts on this process?
Thanks much!
Tim
Geotrash
Dave
Richmond, VA
Thanks much!
Tim
Those threads can handle an enormous amount of pressure, as long as it's not direct hammer pressure. A piece of threaded rod with the same threads as the bolt, then cut just long enough to bottom out in the hole and leave a little bit sticking out for the puller to work against is an alternative to grinding off the shoulders of a hardened bolt. Then use the air impact wrench to tighten the jackscrew on the puller.
I'm assuming you already tried the different length rods that came with the puller and selected the shortest one that would work, yes?
P
Plimbob
Des Moines Iowa
Guys, I have not used my air impact yet, I was fearful of the pressure. Just brute force with a rachet. I used the longest one of the rods which is why it probably bent - duh... excellent point Dave!
I went to my local True Value and could not find a bolt with 2.0 pitch long enough to screw into the crank and bottom out to use. I'll keep looking for one.
I did pick up a short hardened flange bolt to stick through a 1/2 drive short impact socket which I thought I could place up against the crank and then screw the jackscrew against?
I'll keep working at it. I really appreciate you guys taking the time to educate me!
gpracer1
Phoenix
I would heat the balancer where it contacts the crank, but only the balancer, then cool the center (crank) with upside down duster (cold liquid) then hit it with the impact gun.
P
Plimbob
Des Moines Iowa
Thanks Mark for the video!
I tried to look up the bolt specs but could find them, I know it's a 2.0 pitch but not diameter. Would rather find one with regular head so I don't have to grind off so much of the hardened flange of the old one.
I watched the video, make me nervous as !@#$ using an air impact with only screwing the bolt into the crank halfway! Maybe i am being a nervous Nelly but I would feel a lot better seating the extraction bolt further into the crank.
P
Plimbob
Des Moines Iowa
P
Plimbob
Des Moines Iowa
Yup, it is M16 x 2.0 pitch. In looking at the original bolt, the last inch is the only portion discolored, is that all that is actually threaded into the crank?
I went to our local farm implement store and found a 4.5 inch M16 x 2.0 to use to try and use for removal rather than grind down the hardened original like the guy did in the video. We'll see how this goes.
That’s not actually the extraction bolt though- it’s what you’re pushing against. The extraction bolt is threaded in the puller. You can screw the old pulley bolt that you ground the head off of all the way in if you want, as long as it’s still long enough to push against with the puller tool bolt. Add a spacer if needed I guess. The reason for grinding the flange off the old bolt is so it fits through the puller and doesn’t catch. I used an angle grinder with a cutoff wheel and cut that flange off the old bolt in seconds. Once you’ve done that, you can keep that bolt to use if you ever need to pull another balancer. I have done 3 balancer removals this way, it works awesome. So simple too.
P
Plimbob
Des Moines Iowa
Update - I used the bolt I bought at the farm implement store screwed it into the crank end 7 rotations used the puller against it with my 1/2 air impact and after hitting it for 2-3 minutes and then hitting it again for 2-3 minutes with the impact, the third time was a charm, it started moving and got her off.
Thanks much for the input, I was leery of using the impact on it until you all educated me!
Have a great 4th weekend!
Tim
Tim
Awesome news!
Tim
This Forum ROCKS!!
Isn't it GREAT to have a Forum that is actually useful, and actually helps folks get sh** done!
P
Plimbob
Des Moines Iowa
As a recipient more times than a contributor, absolutely! The folks on this forum are always willing to help. This is my go to always if I am stumped on something. However, I also use it not only for education but for entertainment as well as I enjoy reading what others are doing to their rigs.
I have gotten so much help on here, yesterday I signed up for being a supporting member - it was the least I could do for all I have received!
Tim
j_jerry79
