St. Louis
I've gone through a second tank of corn in theothertwin. I am really not impressed with 8 mpg, plus the additional cost per gallon.
Are ya rock crawling or going over mountains when running E85 (or driving like @Doubeleive) to get that gas mileage? Just seems low, well lower than I get, and I've got a bigger engine and larger vehicle.
I was down to about 9.5 on premium before gas went up to almost $6 a gallon now I'm around 11-12 city driving mostly
I have only eased up on the peddle so I don't have to fill up as often lol $100 only gives me 3/4 tank
RooTBeeRthe1st
All of which defeats the purpose of saving fuel costs out of the box.
Yes, more expensive. It's been that way for 1-2 years.
Feed the starving cows, give your car some good ole dinojuice.
Weird, and commifornia e85 has always been cheaper than gas.
10 or 15 years ago, we didn't have a whole lot of stations, and price per tank was about the same as running premium, but you got the benefit of higher octane and cooler air fuel mixture.
Right now it's still actually cheaper than running regular because of the insane gas prices.
I only run it for the performance benefits as well as how clean burning it is.
RooTBeeRthe1st
Apparently my truck Norris cam is still 3 to 4 weeks out. I got everything else though.
Although now I might want to return a few things to Brian tooley and order probably 2k of other parts off of summit.
Took the Suburban camping/turkey hunting/fishing. We were failed turkey hunters this year but successful fishermen. Lots of new hunters this year who don't know the old etiquette. They blocked entrances so only one vehicle could get in (setting aside 1000 acres of public land for themselves), tried to stalk turkeys that I was calling in thereby busting the setup, that sort of thing. But it's more about meeting up with old army buddies, work buddies, and hunting buddies, so it was all good.
I had the tow tune and 93 octane for the first time i think while towing the camper. There is a place on the Appalachian Highway where we have to accelerate and merge going up hill. A trucker way behind me moved to the left lane. I am sure he though wtf when I left him way behind. ;)
View attachment 369662View attachment 369663
Looks like fun.
My lowest MPG on E85 was 7.5 MPG over 12 hours where the average speed was just 13.8 MPH. Truck spent a lot of time idling between towing a trailer to and from storage while moving.
It's combined average over 57 tankfuls is 12.1 MPG.
RooTBeeRthe1st
Anybody running e85 ever have it throw codes? Just put my second tank of e85 & got p0174 & p0171. Lean on both banks. Idol isn't rough & truck runs down the highway fine.
Yeah, you have any way to see your ethanol content sensor?
It's common for the virtual sensor procedure to read much lower ethanol than whats actually in the tank.
it might only read 20-40%E despite it actually being 70%+.
Mine actually ready about 60%E when it was closer to 75+ for months and no codes, didnt realize it was incorrect.
Then it finally dropped to reading 40% and threw a lean code.
Tried the "run a few tanks of regular gas through it to reset it" didnt help. Tank after that reported 20-30%.
Filled up on gas again and used the tech2 to reset it, still no luck after.
Ended up putting a physical sensor on it and no issues since.
lowh07
Alright this is driving me absolutely nuts. I have the radio pulled apart again trying to get steering wheel controls to work. Pioneer DMH-A245BT with Crux SOOGM-16 interface.
When I go to the steering wheel control settings on the Pioneer, it tells you to hold down the button to register... well it is treating both volume up and down buttons as a single button. So when I try to assign one function, it unassigns the other, but both buttons will volume up or down only. Any ideas??
Buy a Maestro interface. Never heard of the Crux. With the Maestro, programming is done with a browser.
RooTBeeRthe1st
Yeah, the maestro makes it super easy. I didn't even have steering wheel buttons when I bought the car, had it in got the maestro looked it all up to the pioneer and everything worked perfectly.
13UpInSmoke
So you replaced the factory sensor? I just put 16 gallons of ethenol free gas plus a can of VP quantum octane booster to see if I can can get back to e10 ish
RooTBeeRthe1st
Well, the virtual sensor isn't actually a sensor. It does some weird magical test stuff between the oxygen sensors and fuel trims and such to roughly figure out the alcohol content. And most of the time it actually works good enough.
But for some reason that system happens to get angry and read very incorrectly.
So there isn't an actual flex fuel sensor from the factory, but you can add one like the older(and newer) vehicles actually came with.
But you have to go into the tune and tell the computer that it now has a physical sensor and not a virtual sensor as well.
Sparksalot
Bastrop County, Texas
Not sure if there’s anything to this, but…
The AC on thecopcar seems kinda slow. The air coming out is chilly, but doesn’t seem to be moving fast, unless I turn the fan way up. I usually leave it right in the middle.
I t does get cool inside, but it’s taking a little longer than before.
I pulled the gauges out this morning to test it. Compressor ON, it reads 175 on high and 32 on low. Compressor OFF, it reads a bit under 150 oh high And 55 on low.
the empty can on the gauges had a bit in it apparently. It got chilly for a bit. I didn’t see any pressure changes, so it wasn’t much.
wjburken
Eastern Iowa
If you put it on heat, do you get the same air flow or is it just on A/C?
schafer98
