Tonyrodz's Tahoe Build Thread
Which side is bank 2?
Ds? I'm thinking exhaust leak.
Also I think the rear is on it's way out. I floored it going down the road and it sounded like I blew it. Clanging noises were coming from underneath, kind of sounded like the trans area at 1st. Still in gear i was stepping on it and nothing. I put it in neutral then in gear, little more clanging then it stopped, went into gear and it drove. Stepped on it again and i heard some banging coming from the ds rear area(sounded like it was coming from that area). Govt lock?
Don't hear any noise in the video, but it was off in park and I was able to turn the rear wheels while in the air and the driveshaft wasn't moving. Doesn't seem to be any real play in the ds, as in U joints. Opinions or ideas?
Could it possibly be the transfer case making that noise? Even tho the prop shaft for the 4wd isn't connected? It kind of sounds like that's where the noise might be coming from--from the front. I originally thought it was the trans.
Quote
Quote
Could be. Gonna have to have someone listen while you shift back and forth from D to P or you listen while they shift.
It doesn't make noise while shifting it, when you power brake it. I'm not sure if it happens when take turns, or hard turns.
26AT4
