DOD FAILED. CAM THOUGHTS
D
decembersend
I put the TSP headers, Y pipe and Corsa exhaust on last night only to find out the Flange that's suppose to connect the Y pipe to the Flex pipe on the exhaust doesn't fit. It's only 3" where as the factory and Corsa is 3.5". I called TSP and they told me this is because the Y pipe is meant for a 5.3L and they don't make one for the 6.2L. I wish the disclaimer on the website stated such instead of saying that some modifications are required for the 6.2L.
So I just left the muffler shop with the old flange and the new flange to have them cut and merge the two.
D
decembersend
I have the truck up on a trailer ready for a Tune tomorrow.
Prior to putting it on the truck I checked codes and I’m getting a U0121 among others that are expected.
Is the U0121 (brake and abs lights on) normal after these mods? Putting it on the trailer I could tell there was something wrong with the brakes.
I can't think of anything directly related to your mods that would cause a loss of communication with the ABS module. Maybe you left something unplugged or pulled a harness? First, check the pertinent fuses. Then give the harness and connectors a good visual inspection starting at the ABS module and tracing the harness back, paying special attention to the areas you were working in.
D
decembersend
I wish I was
Just my luck not allowed to be that easy. I wish I would’ve figured this out sooner but it is what it is.
The fuse box is on the the driverside and so is the abs module.
To the best of my knowledge I get touch or do anything to that harness.
I just looked at the fuse and it’s good. I can hear a relay clicking just before the brake light comes on in the truck.
I will look at the harness and hope for the best
D
decembersend
Well I’ve looked abs and find anything without either probing wires or ripping into the harness.
I did forget to mention I had the battery disconnected since November to prevent the battery from dying. Something is telling me it has something to do with that.
I wish my truck was garaged but I don’t have the room. If it were I would’ve just put it on a trickle charger.
These things do crazy shit when they have inadequate or no power. Clear the code and see if it returns. I wouldn't clear all the codes in case your tuner needs or wants to review them.
Geotrash
Dave
Richmond, VA
Silly question, but did you remember to reconnect the vacuum booster line from the manifold?
D
decembersend
No such thing as a silly question, but yes I did.
It’s at the tuner now. It’s been there since 8am and I made him aware of it, so far no phone call so I’m hoping I’m good.
Geotrash
Dave
Richmond, VA
Good! Fingers crossed!
The first cam I installed had a choppy idle resulting in such poor vacuum that I would get weird brake pedal behavior when backing out of the driveway, and would sometimes get a brake fault. Since installing a different cam with a smooth idle, no more problems. Hopefully your tuner can get it sorted.
D
decembersend
The tuner said he has the truck running great with just a street tune and hasn't put it on the dyno yet but will tomorrow morning.
He told me without digging into it to much (opening up the harness) he wasn't able to talk to it with his computer. So I be saving that for myself as I'll be able to drive it home after the tune.
Can you do me a favor being that you have the 6.2L can you look in the fuse box under the hood and tell me if you have a fuse in #9 abs2? I looked last night and don't have one there and I don't recall removing any fuses. The book is terrible for the 6.2L.
D
decembersend
I think I figured it out but I don't have the truck to confirm. When I was priming the engine for oil I was looking for the fuel pump relay and or fuse, I guess with the 6.2L the book and print out are fully meant for it. The Fuel Pump relay is in the back by the spare tire.
Anyways while searching for this I believe I took the fuse out of ABS2 #9 and put it into the fuel pump #20 which wasn't there to begin with. My fuse block is pretty dirty and when I opened it up last night I recall seeing clean spots there as if I pulled the fuse out but it didn't dawn on me until now with what I would've done with it if anything.
D
decembersend
Anyway you can look at your fuse block to confirm please, this will seriously bug me all night lol.
#9 25amp
#20 empty
Geotrash
Dave
Richmond, VA
#9 25amp
#20 empty
That's correct:
D
decembersend
@decembersend Any updates?
Drivability, idle, exhaust loudness, etc?
Sorry it’s been awhile since I posted and I still need to work on a build thread.
It’s amazing to drive and I drive it about 80miles everyday. Mainly highway but it’s perfect in the city as well.
It idles great.
My only issue which is my fault for not buying it already is the stock converter is to weak it causes me to keep the brake to the floor while sitting at lights otherwise I hit the person in front of me. I can’t even let up a bit.
I’ll upload a sound clip of the exhaust to YouTube and here's the link. CORSA EXHAUST CLIP AT IDLE
To me the sound (loudness) is perfect but my neighbors may disagree Lmao.
BadDaddy2003
