Oil plug tool
S1W99
What specific wrench or tool do I need to remove the oil pan plug when changing my oil? I'm not looking to buy a whole set of anything, just the one specific tool for this use. I've seen mention of a torque wrench but that seems a bit much.
Thanks
pwtr02ss
Tennessee
Just a 15mm wrench and an oil filter wrench for the filter. If it has a replacement drain plug, it's probably 13mm. My magnetic aftermarket is 13. Oem is 15
me51
Germany
The required socket is 15 mm and the torque is 25 Nm / 18 ftlbs for the screw and 30 Nm / 33 ftlbs for the oil filter itself.
97YukonNZ
This guy will use Vice Grips
MassHoe04
Western MA
Was never anything I'd bother getting a torque wrench out for.
Just has to be tight enough to keep oil from squirting out.
I go hand tight, then just a little extra with the filter wrench. Just a little bit more than hand tight. Just until I feel a little more resistance. Just by feel. Seems to work OK for me that way. They stay on, don't leak and come off OK the next time.
Durobans
