Drwinlied
Replaced door actuator. Dont worry, theres slack in that cable despite it looking like its holding everything up.
While there, found out maybe why my sound isn't quite up to par
justchecking
Military
SW Ohio
Mine have a bit of corrosion. My Suburban is white, and I have a bit of corrosion. If yours are in good condition, I submit the first bid on your old ones!
justchecking
Military
SW Ohio
I'm going to be needing new tires probably in the next couple months and also want to get different wheels. I want something darker (black or dark Grey) with maybe machined edges. Something like what @George B has, but not necessarily that 5 spoke style.
Anyone know of any decent places that sell wheel/tire combos, or anyplace that sell new model take-offs?
First time quotes didn't work! May have been the Four Roses? Anyway.
Mine have some corrosion. If your old ones are in good shape I submit the first bid!
noticed the power steering pump has developed a little whine over the last 3-4 weeks, works fine but I am going to try flushing it and see what happens ordered some ac delco fluid off of Amazon since nobody else stocks it but the dealer, I have been flushing it annually but I think I skipped it last year, go figure....
St. Louis
Speaking of power steering, is the reservoir on these replaceable, or do you have to replace the entire pump or rack, etc? Reason I ask is because the outside of my reservoir tank is rusty as hell
as far as I know the only part of it that be can changed is the pulley, the rack n pinion is a completely separate part, the pumps with hydro boost may be different, not sure.
26AT4
