Need help
FINALTOUCHFRI
Florida
Just recently, I was on the highway and I punched the gas and I heard a loud pop under the hood. I didn't loose any power in the truck and it ran fine all the way home but when I parked the truck and let it idol, there is a loud ticking under the hood, like a bad sticking valve or something. Also notice oil gauge is fluctuating. Dont know if its related. The truck idol fine with no shakes or misses.
donjetman
Those pesky punch WOT situations.... Last summer, I pulled a WOT at a stop light, and it blew my heater hose right off the Tee at the fire wall and emptied my coolant all over the engine bay and street.
I had the same thing happen a couple of winters ago. Plastic T broke. I had new aluminum Gruven Ts in the seat back pocket that I had been putting off installing. Forced my hand and all has been well since.
89Suburban
Bull in the china shop
SE PA
Heater Tees?? Do you thing he would make it home??
FINALTOUCHFRI
FINALTOUCHFRI
Florida
Well finally got truck to shop and the bad news is, I blew a valve, that's what is all ticking about. They are telling me I need a new motor and its not worth putting any money in a motor with 220K miles. Any suggestions. Used 5.3 are going for at least $2,500 with low miles. Or do I get the heads done? The motor already needs rear main seal, valve cover and oil pan gaskets. What do you suggest. The trucks interior and exterior is 100%
what is the 8th character in your vin?
Geotrash
Dave
Richmond, VA
Damn. If you dropped a valve, then there's damage to at least the piston and probably the cylinder walls too so you'll need to pull the heads at least, but will likely need a new block and bottom end too. Sorry to hear the bad news. $2500 for a low mileage unit seems like a fair deal if you love the truck and it's still in good shape.
AEHaas
