2003 Tahoe coolant system leak or head gasket leak?
tRidiot
Yours look to be pretty smooth and 'glazed'.
This is what you want, from what I understand:
This is what he meant, I'm not sure too much if this is something you should go tearing into, since you're just doing a top half, but I'm not an expert. I just recognized what he was talking about - has to do with oil coating the cylinder surface, seating of the rings, etc.
MassHoe04
Western MA
If it were mine... I see nothing of serious concern in photo of the cylinders. If you were doing a full block tear-down with new pistons and rings, I would want to hone the cylinder walls to get that nice cross-hatch pattern on there to help new rings and pistons settle in.
If the pistons and rings are staying in, I would leave the cylinder walls alone. Especially, if spark plugs and injectors had no oil on them and there was no oil consumption or blue smoke. Don't poke the bear!
Other than a good cleaning, I would not mess with the cylinder walls unless new rings were going in. Changing the surface profile of the cylinder walls and keeping the old rings might just be asking for new problems...
I would clean the walls and call it good. I would vote for no honing, if not putting in new rings.
T
tomloans
Well, this is interesting news. Prior to teardown, motor ran like new with lot's of power. No smoke at all. Spark Plugs are perfect, injectors were amazingly clean and the build up of carbon on the cylinders and valves was what I would consider normal for this many miles. I think I am going to put it back together and call it a day. I have about 210k miles on it and I am hoping to get another 5 to 10 years out of the motor and then figure it out then. We put about 6k miles per year max on this vehicle and hopefully I will have it for another 10 years. My wife loves it and doesn't want to get rid of it.
I think if I were to mess with the block, I would just drop a rebuild in it and keep the heads (for the inevitable problem on my other 03 Tahoe - I have 2 Tahoe's).
Well now I am concerned though. If I have this kind of wear on the cylinder walls, wondering how the rod bearings are?
tRidiot
It's not really bad wear - it's expected glazing after this many miles. I wouldn't expect good crosshatching with this many miles. As @MassHoe04 noted above, I don't think you should worry about it. It ran, there were no signs or symptoms of trouble with the block, leave it alone.
T
tomloans
Yep that's the plan. Can't tell you all how much I appreciate the insight and the experience. I have done a lot of work with these cars over the years I have owned them but this was likely the most extensive so far. The little idiosyncrasies are what experience provides so you don't botch it. Also for the record, I reattached two very weak grounds in the back of the engine as well. One broke as I was working on the engine. I reattached them and pulled another ground directly to the battery just to be sure. These grounds can cause all kinds of havoc if not attached solidly.
T
tomloans
What are these for....? Valve Stem seals? I dont think I need them as the new heads have them installed?
Yup- valve stem seals. Blue for intake, maroon for exhaust. Save 'em for a rainy day or for someone else in need.
You likely caught a problem waiting to happen. Might I suggest adding a Big 3 upgrade to your "bored" list?
T
tomloans
"Might I suggest adding a Big 3 upgrade to your "bored" list?"
Chris, I have no idea what this means. :(
It's up grading the wire gauge of the three main power circuits: Battery negative to frame, engine block to frame and battery positive to alternator charge post.
I did a "Big 5" by upgrading the starter positive and body sheet metal to engine block ground.
My junk: https://www.tahoeyukonforum.com/threads/growing-up-doesnt-have-to-suck.93510/post-1567413 and https://www.tahoeyukonforum.com/threads/growing-up-doesnt-have-to-suck.93510/post-1567416
...Part 2: https://www.tahoeyukonforum.com/threads/growing-up-doesnt-have-to-suck.93510/post-1570382
...aaand, finally, Part 3: https://www.tahoeyukonforum.com/threads/growing-up-doesnt-have-to-suck.93510/post-1615659
mattbta
Frisco, TX
@iamdub - i would totally buy a set of wires off you if you ever got bored. That's out of my wheelhouse.
Sorry for the hijack @tomloans - great work on cleaning the surfaces. I didn't do near as good a job on the tops of the pistons as you did. I agree with the others - slap the new top end on it and send it! You caught yours way earlier than I did, so my plan is to just send it, too, and expect my cam bearings at some point to go. At that point, hopefully I'll have rebuilt a longblock and upgrade. (But I'm going to put the Truck Norris cam on this motor just for fun and I'll get a better look at the cam lobes then.)
tRidiot
Big Three upgrade is always a good idea on any vehicle, if you ask me.
Here's what mine looks like:
Slightly more modest on my 370Z:
lol
T
tomloans
Oh Man am I into this. Great work. I have had so many grounding issues with this car. It will be awhile before I get to it as I have a 2001 740i with a pretty good oil pan leak and oil sensor seal leak as well. Plus I did a complete overhaul on the cooling system on this one as well and one of the hoses behind some plastic is leaking. So that is next after this one. It never ends. :rolleyes:
tRidiot
that is crazy! You relocated the battery? Can't figure out where that is.
No, that is looking over the engine compartment from the driver's headlight area. Battery in that shot is directly under the bottom of the picture. There's also a second battery on the passenger side up by the firewall, an Odyssey AGM. I have since separated out my stereo electrical and vehicle electrical. Stock alt runs the vehicle and stock battery. 300A Ohio Generator alt runs the AGM battery and the whole stereo system.
mattbta
Frisco, TX
I put both heads on first and then rockers. Can't comment on your question, but here's the service manual process for the rockers - they are torqued in a sequence in totality.
  • ROCKERS.pdf
Thank you. It's all budget stuff. You don't necessarily need 1/0 cable, I just used it since it's what I had. Grab some 2AWG or larger from a welding supply shop and the lugs, heat shrink, solder, etc. off Amazon.
JamesinAbilene
