Lifted/Leveled 2021 - Postem Up
olyelr
Elk Rapids, MI
Thanks! Looks like Chevy.com is only showing 6.2 with AAR for the 22 Z71.
EDIT: the 22 High Country does show available in 6.2 without AAR.
So maybe if you get the 6.2 with the z71 then you are forced to get the aar. They do stupid shit like that sometimes.
I would certainly check with someone besides just the online build site…those are notorious for being incorrect.
RHStansbury
Annapolis
Anyone running the RC level with stock rims and tires? I'm thinking about getting the level knocked out now, but feel like swapping tires at 300 miles is a bit ridiculous.
sanman28
That is correct. 6.2 z71 comes with AR for the time being…..that’s why I got the AT4. Wanted the high clearance front end and off road look and the 6.2 but without the air ride.
R32driver
Depends what tires you got stock. Ours came with Continental Crosscontact LX 20 tires and they are junk IMO and had to go immediately. Ridge Grapplers that replaced them are SOOOOO much better
sanman28
Looks like THIS is the only "advertised" level for a magnaride non-air ride yukon.......anybody else see others?
My plan (for my AT4) is the 18" wheels off of the sierra AT4 from last year, powder coated black or brass, with 295/65/18 duratracks.....i hope a level will fit them. Better yet if somebody has done a 2" + and it worked. No idea how to tinker with the magnaride until i get the thing.
Perhaps a 285/60/20 on the stock rims if decide to keep them.
This High Country clearly has some lift....and all those have magneride.
tedgen2
Had a RC 2” in the front and 1” in the back installed today. Stock rims and offset with 285/65R20 Ridge Grapplers. ‘22 Yukon XL AT4 with no AR. Minor rubbing on the inside of the fender that I need to cut. What’s odd is that it sits around 1/2” higher in the front. May need to add another 1” in the back.
olyelr
Elk Rapids, MI
Hard to tell with the dark pics but looks like it sits level or slightly higher in the back.
Looks good to me! And i hate when they look like they are sagging ass
RHStansbury
Annapolis
Looks fantastic! If I'm not mistaken, this is the first time I've seen someone run 285/65s with just the Rough Country lift. Are you just cutting felt/plastic, or is some metal going to have to go too?
tedgen2
Just felt/plastic and not much at all.
fntiger
It’s possible. You can try contacting Hurst Autoplex
But apparently they don’t share their secrets.
olyelr
Elk Rapids, MI
RHStansbury
Annapolis
It says its a 4” readylift with 295/60/20’s…
It does, but if you ask Readylift, they’ll tell you that they are not sure how Hurst is doing it. Hurst references a 4 inch kit which is what was available for the previous gen. They started selling their lifted 2021s before Readylift had anything on the market for the current gen.
VAguy68
Did you use any wheel spacers? I see on the RC site where all three customer examples used 2.25" Bora spacers. Is this critical? I'd rather my tires not stick out past the fenders if possible.
tedgen2
I can take some in the daylight tomorrow. Long day!
Here are some more, think it sags a little but may not be noticeable enough to go add to the back. The 6.2 is nice!
sanman28
Awesome! And thank goodness for your info. Exactly my plan. Is it this kit you used?
Lift
Andylbc
