cmatt
Nice! Check the rear coolant crossover gaskets too. Probably wouldn’t hurt to invest in a new VLOM while you have it apart but that’s up to you. And the oil pressure switch and screen too. Did you have any of the disintegrated foam under there?
Interestingly the rear coolant crossover pipe isn't present in my 2012. Lol the only new VLOM I'm investing in will be one without AFM when I delete it. The foam was acutally intact, but the front piece wasn't in its place.
Monz11
Da Burg, Fl
Had an intake manifold leak to tackle today. Sounded like a choo choo train on a cold start when the engine idled down. Lot of caked on dirt and remnants of disintegrated wire loom under the manifold. Three of the ten vlom bolts were finger tight SMH.
Did an injection service yesterday in anticipation. At 150k miles, the upper part of the cylinder head ports still had some gunk on the walls, but you could see where the injector spray was hitting them. The valves were pretty clean as expected.
Might as well tackle the AFM/DOD delete, cam upgrade while your at it
A little Sunday evening stretch
Im in the market for control arms. Never seen these adjustable ball joints. When would someone need these? Im at stock height on 22s with the autoride.
For someone who is lifted, lowered or was in a car accident.
How long did it take you? How far are you from my house, I need it done! LOL
I always forget to play with that on the head unit.
part of the trip there was I think a Porsche playing p@ssyfoot with me, lol makes me want to get a SC even more but even then I know I won't be able to play serious with a vehicle half my weight and 1/3 size but it was a little fun without getting to crazy
RooTBeeRthe1st
And having some sort of battery issue. I've noticed slow starts for a while now, finally disconnected my optima yellow top that I added.
Lights on, but didn't start on the champion AGM that I put in 8/25/20 from pepboys...
Need to test the battery, if it's bad I hope the pepboys service centers will trade it out for me(48mo warranty) since they no longer have parts stores.
Tried resetting all the tires to 30 psi. FAIL. Two tires would not register updates on Tech-2 or DIC after letting out copious amounts of damn air. Took her around the block and one more went up a pound! I quit!
how old are tpms sensors? this can happen when the battery gets low, they either do not register or will register with a weird reading
they have parts store's here, we have 2 of them in town at least we did as of a few months ago
yep here's one and he was just out for a ski, The body of a skier who vanished in a Lake Tahoe-area ski resort on Christmas was found Saturday, miles away from where authorities and volunteers had been searching for him. Search-and-rescue volunteers discovered the body of Rory Angelotta, 43, near a residential neighborhood and roughly 3 miles from the boundaries of the Northstar Ski Resort, the Placer County Sheriff's Office said in a statement Saturday.
took 3 weeks to find him and that is in a populated area, sounds like he almost made it though....
ASG-MikeS
