07Burb’s 2013 LTZ Burb Thread
Parts for a mild drop purchased. Going with Belltech coilovers for the front and McGaughy springs for the rear. Goal is a 1/2 to 2/2 drop. Should be just about perfect for what I’m going for. I was at 3/5 with my 07 and was super tired of the issues that came with that by the time I sold that rig so don’t want to repeat that again. Good thing with these coilovers is I can adjust ride height up or down so I’m not “married” to a specific set up if I want to change things.
Hoping these arrive next week and I’ll install them soon after that. Shouldn’t take more than a few hours to accomplish.
Looking forward to pics. Don’t forget some before as well as after.
Surprisingly my parts should arrive by Friday according to tracking. Kinda surprised considering how long it takes most stuff to arrive these days
I would like a 1/2 drop on mine but to also retain al the factory suspension systems like the air and auto ride... Dreams...
Yeah that’s another reason I’m staying pretty mild so that I can keep my autoride.
Aren’t those “dumb” front struts?
Yes. Coilovers. I was talking about the rear auto ride. Do you have some kind of fanciness in the front???
I did a 2/4 drop on my 02 and retained auto level. I just had to cut threaded rods and try several lengths to get it to where it would just barely lift it back up to where I wanted. Then once set, it consistently keeps it at that exact height no matter the load. I was running 26’s for a long time with barely any fender clearance and at one point I did a trip with 7 people in it with a load of gear. Also hauled a heavy trailer a few times. Never scraped a tire. I’m running 22’s now with a bit more clearance and the system still performs perfect.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Perfect. I looked around for a bit and struggled to find a 2" drop spring for the rear. I am not very serious about it. Many other fish to fry.
…and with the shock extenders you shouldn’t have to do any mods to the autoride system from my understanding
I think the suspension position sensor rods would need to be adjusted.
I re-read my post and see I didn’t specify what the threaded rods were for. It’s the ride height sensors. The shock extenders won’t keep the system from airing the shocks up. The height sensors are mounted between the upper control arms and the frame and not the shocks so when they see the truck sitting low they think you have a heavy load and will attempt to raise the rear right back up to where it normally sits. If you don’t shorten them, you’ll be right back where you started height wise. Some kits come with shortened rods but in my experience it takes some trial and error with different lengths until it airs it up just where you want it. You need to reset the system every time you change the rods out by removing an air line from one shock which lets all the air out of the system, then start the truck and observe how much the system raises the truck. It should just barely raise it, or to where you want it to ride. If it doesn’t raise it at all, the rods need to be a tad longer or else the system isn’t working. It needs to partially support the weight, and if it doesn’t, it won’t be able to lift it up when you add weight. 1/8” difference in the rods equals about 1/4” in ride height iirc.
George B
¯\_(ツ)_/¯
I imagine these could be set using a tech2 looking at the live data. Just record the before and set the sensors back to the same reading. Then do an ALC trimset cal.
Can just get these. Should be an easy mod to do
Possibly but when I did the trim set calibration it screwed everything up. Wish I’d never tried that. It took forever for the height to settle back down.
Lol. I bought some screws with the same threads as the stock rods from Ace for about 20 cents each and cut the heads off. :D
George B
¯\_(ツ)_/¯
Probably because of the way you set the system to slightly raise your truck from static. I have run the trimset twice. It seems to set the zero at wherever the truck sits static with a full tank and then compensates for sag.
BadDaddy2003
