2010 Passenger Seat Recline Issue
Schimpfy
OH
I've tried a search for this, but I'm not sure I'm looking for the right thing...
The passenger seat in my wife's Yukon will recline just fine, but won't come back upright. Obviously, the motor works so that's not an issue. I took everything apart and reset the seat to the upright position mechanically and it still works to recline but not to the upright position.
I haven't been successful in finding a schematic of the seat components so I'm curious if there's a stop switch to prevent over travel of the seat in either direction or if it's internal to the main switch.
Big Mama
Virginia
Welcome Michael. Does the motor get power from the switch in both directions?
wjburken
Eastern Iowa
Sounds like your switch assembly has gone bad. It’s an easy fix and costs about $50 for the switch.
Nightshade715
Did u ever find the solution to this problem have this same problem with my 2013 yukon
Big Mama
Virginia
You can also check the control module for loose wires. When mine got stuck in my wife’s 5’2” position I was able to do this to move it back.
blondie70
My seat adjusters don't work either. I had the seat out and everything looks good under there (Replaced the cushion). Glad it's stuck in my position...ha ha
Bwaldron
