2001 Burban, almost no oil pressure even after replacing the oil pump
ScottyBoy
Shreveport, La
So some of you may already know my situation as I've mentioned it in another thread,but I figured I'd make a dedicated thread for my issue.
This all started about 2 weeks ago, I got a "Low Oil Pressure " warning light on my dash, and my oil gauge dropped to just below about 10psi. I replaced the oil sending unit, NO CHANGE. So then I bought a manual pressure gauge, and after hooking that to my engine I saw that it was reading the same as the stock guage on my dash. So I ordered a new oil pump and pickup tube/screen. And if course all the needed gaskets and seals involved when you remove the water pump, timing cover, and oil pan. So I pull the oil pan and it's FULL of thick sludge. The screen was also mostly clogged with sludge and debris.
After much scrubbing and cleaning, I finally got the oil pan completely clean. Then I removed the front timing cover, and thankfully saw that the rest of the engine although not exactly CLEAN, had nowhere near the amount of sludge that the oil pan had.
So after much cleaning, (and aggravating my back) I FINALLY get the new oil pump installed, the new pickup tube and O-ring, then re-install the timing cover, oil pan, water pump, crank pulley, and everything else that I removed in the process. Get it all filled with fresh oil and fresh coolant, then I pulled the plug behind the power steering pump and wedged a hose into that hole to prime the oil pump as many videos across the internet have instructed to do to on LS engines. After all that, I finally go to start it up and I have a VERY loud lifter tap, and very low oil pressure. I figured maybe it just had some air in it so I I let it run for a minute to try and warm up and hopefully bleed any air out. At this point the oil pressure was about maybe 15psi. I revved it and got it up to almost 30-35psi. After a few minutes of letting warmup and trying to bleed any air out of the oil and the coolant, the lifter tap finally quieted down a good bit. I've always had a lifter tap ever since I bought this rig, but it's usually pretty quiet, and almost completely goes silent after the engine warms up. This was the loudest it EVER been. Was so loud it almost sounded like a rod knocking. Anyways, after warming up the engine for a few minutes, the oil pressure got even lower. It was no higher than about 5psi at idle unless I increased the engine RPMs.
I installed a Melling "high volume" oil pump so I figured I should have even MORE pressure than normal. Something is obviously wrong here, and I have no idea what to do at this point. The ONLY thing I can think of is to drop the oil pan yet again and double check the O-ring on the pickup tube. Also thinking I should do a compression test to double check that I don't have something wrong with my engine.
Does anyone have ANY suggestions or insight for me at this point? I've thrown so much money at this thing the past two weeks between buying all these parts, all new fluids, and several new tools I had to buy just to complete this job. I'm just VERY frustrated with it at this point. :confused:
GMT800 2005 Tahoe Z71
Navy Supporting Member
With all that sludge and over time, the low oil pressure, I would be worried about crankshaft and camshaft bearing clearance. Sorry to say that the damage may already be done but yes, double check that o-ring. With the sludge from before you may have drain back problems at the heads as well.
blueinkd
So when I did my rear main seal I made certain to replace the oil pressure barbell. Cheap piece and is a big part of the oil system. I wonder if maybe the oring on yours has failed. Just a suggestion. See video below.
drdave81
Waterford, MI
You may also look into the pick up tube girdle. It keeps the pick up tube from moving in the oil pump by bolting down the other side of the tube. If it's not that though, I think you're looking at major work here. My first thought after reading was also bearing have gone bad. That much sludge is a big indicator of maintenance neglect.
S
ScottyBoy
Shreveport, La
I agree, I should have been changing my oil more often. I don't put a lot of miles on my truck and I was changing the oil based on MILEAGE and not paying attention to the age of the oil. Apparently low mile OLD oil can be just as bad a high mile oil.
Yes it can. Did you use petroleum based oil or synthetic? What brand and quality of filter. Cooling system problems, too hot, can break down oils as well. Leaking oil and then throwing in what you have around can cause problems if not the same oil as what is in the engine.
S
ScottyBoy
Shreveport, La
ALWAYS use Synthetic oil, and I usually either use Amsoil XL Series or Mobil1. For filters, I either use a Mobil 1 filter, or a Wix XL series filter, depending on what's easier to find at the time. Sometimes people are out of the Wix, sometimes they are out of the Mobil1 filters. I usually order a case of Amsoil, but the times I forget to order, I just buy some Mobil 1 oil locally. I have been running my oil for about 5500 miles, but that can sometimes mean I go nearly a year on that oil. I now realize that's a VERY bad practice. I need to change it every 6 months even if I only put 2500 miles on it.
Yes, max time for me is 6 months, even with synthetic. Good choices, IMO, on the oil and the filters. If you are only putting a low amount of miles on the engine in a year's time, that means the water condensation that builds inside the engine as it warms up and then if shut off soon after, that water drips in to the oil and contaminates over time. Is especially brutal on petroleum based oils. As I said above, other factors can contribute to the oil break down over time. Plus, problems with the engine that are great one minute can be bad the next, like fuel contamination that exceeds the normal small/minute blow by.
PNWYukon
Olympia, WA
from: https://dannysengineportal.com/engine-oil-sludge-is-caused-by-your-engine-oil-breaking-down/
"The simplest solution here is to use a, chemical engine sludge remover. There are some sources that don’t really like them; but they are the easiest way, to get rid of sludge. They are typically added to the old oil; then you idle the engine for 5-10 minutes without driving it. This gives the chemical solution time to; dissolve the sludge and draw it back into the oil. Then you change the oil and the engine sludge, is removed along with the old oil. Finally, be sure to follow the specific application directions, for whatever you are using."
Maybe this could help, but I have never seen sludge like that.
S
ScottyBoy
Shreveport, La
I tend to disagree with some of these assumptions, based on my DD's latest oil report from Blackstone:
Well I'm hearing LOTS of mixed opinions then. Some folks claim it CAN break down simply with age. Some claim that you can go up to 12k or 15k miles on some oils regardless of how many months or years it takes to go that many miles.
I look at it this way. Changing the oil too early, according to what some say, is still cheaper over the long run than buying and installing an engine. Plus, drag racers change their oil every 1/4 mile.
I agree and shorter intervals make sense to me as preventative maintenance. I do try to make my trips full warmups. Remembering how many miles on the oil analysis I posted, it had to be less than 4K, mainly in town driving. But the engine computer said it was time. Granted, I've had the Fusion for only 2 years, and Grandma did a lot of short trips while she had it the previous four years. She was great, however, on getting the oil changed each year or 1K miles (her average was about 850 miles each year).
I change my oil every 2500 miles with conventional oil. The most I've gone was 3000. Now that I think about it---I'm pretty sure my oil pressure problem started when I had a garage change my oil. Unbeknownst to me he used synthetic, which I'm assuming knocked all the sludge that was already there loose, probably clogging the pick up screen and starving the bearings and everything else. I was shocked when I saw the amount of sludge in the pan. Since everything has been changed my oil pressure is great.
treehan77
TYF Fiend
Crestview, FL
I change mine every 5k or 50% of the DIC, whichever happens first. I highly doubt JUST waiting till 7500 or even 10k using synthetic is causing that much sludge, almost has to be some other problem. When I did my pan, there was zero sludge. I also saw several GMT800 trucks that routinely only go the DIC (usually around 10k) and none of them had sludge like that either. IMO it’s still cheap insurance to change it often with synthetic though!
blueinkd
Quality oil won't sludge up unless it's getting mixed with something else like coolant or moisture. I have been using Mobil1 full syn for years and hard, all the way up to 8-9k miles. Never had a problem with it flowing out sludged up. Mobil1 extended performance had never done me wrong. U must have something else mixing with that oil causing it to sludge up. I'm running it in the tahoe or Penzoil Plat full syn 5/30 every 7-8k miles. No issues here over 2 years now. But I'm fairly certain my rig saw decent maintenance before I got her.
You really won't know until you open that thing up. Wish there was an easy answer but with that kind of oil pressure your idling on borrowed time.
Larryjb
used car prices just collapsed Now what? I was checking out CL prices dropped... by 50% guys
Moisture causing sludge could very well be due to condensation. Short trips aren't allowing the oil to get hot enough to expel the water, so it accumulates and sluudges the oil.
Phlipnstik
