Just Fishing
Can't fix stupid
Utah
I haven't had an issue with #8 plug.
it could be easier, but using a swivel headed ratchet and a socket.
I don't recall if i needed a swivel bit or not, but it's not that bad.
Found getting the plug boot off was the hardest thing about it.
I found i like to loosen it manually, then zip it off with an air ratchet and some extensions /swivels.
I'll do the same installing, Start the threads manually.
Then zip it on with my low powered 1/4 air ratchet, then torque it down manually.
Wee air ratchet i have: https://www.amazon.com/gp/product/B000RVGHD6
Only complaint is it can get warm when used heavily.
Metal body...
Just Fishing
Can't fix stupid
Utah
If i were to do it again ^
I would just get the Astro version of that.
IIRC at the time, the Neko was quite a bit cheaper.
And i just saw this in suggested...
Astro Pneumatic Tool 1119A ONYX 3/8" Drive Mini Wobble Air Ratchet
I might need that in my life. :ehcapt:
ETA: yeah i ordered it... :jester:
Kee Fuller
las vegas
Changed 7 out of 8 plugs today. Ran out of time to get to number 8. Thats gonna be a absolute pain in the ass. I cant wait!! Driver side plugs looked like crap. Its also the side im getting some sort of noise on...fearing its the lifter failure. Passenger side plugs all looked decent enough for 90k, but definitely time to go. After plugs, the noise seems to be less and only when revving down towards idle. its kinda hard to hear at times. E85 also seems to have helped with it.
Be careful and not do what i did. Leaned on one of those hose’s and snapped the cooler Tee.
Better yet, if the Ts have been on there for a while, get some new OE ones and intentionally break the old ones off. Replace with new OE and they should be good for a long time. Get rid of the ticking time bomb.
Kee Fuller
las vegas
I ended up getting 2 of these
Merch619
