Anyone near Greensboro/Winston-Salem, NC willing to look at a truck?
91RS
GA
I figured I'd throw this out there since I think it was worked for others in the past but is there anyone near the Winston-Salem and Greensboro area NC willing to take a look at a truck for me? The pickier you are the better! I really want to go look at this truck but it is 4.5 hours away so going to look at it will cost me an entire day plus probably $125+ in fuel. This truck is almost the perfect one option wise (main issue being AWD) but I'm nervous it might be rusty because it was registered in VA for a while. It's at a little car lot rather than a new car dealer and they're hit or miss with trying to do crap like spray painting the frame and such to try and make it look better than it is (or doing it as part of the detail process and then the truck stinks like spray paint). I'm VERY picky about paint (at least on the body, I can forgive bumpers for the right truck) and most importantly want to know if it has been painted poorly and there is dry spray, sanding marks, etc.
Big Mama
Virginia
Depending on where in Virginia it may not see snow. I’m about 2 hours north on Greensboro in Roanoke VA. We see 2-3 episodes of snow per year and the road is clear usually the same day. Good luck with your search.
91RS
GA
The truck got sold on Friday. Probably for the best. I would have been buying for the color (Xenon Blue) and probably would have hated the AWD 6 months after buying even if the rest of the truck was in good shape as it appeared to be in the pictures. I just need to keep my SWB and buy a roof rack or hitch carrier for down the road. It’s paid for and almost everything is fixed on it.
ARA Auto Sales?
91RS
GA
It was a place called Walkertown Auto Sales which appeared to be run out of/through Walkertown Tire.
RichardCranium
Mebane, North Carolina
Sorry man, had a pretty hectic weekend with staffing at work with everything going on! Let me know if you find another this way and I'll be glad to check it out, pending the work flow.
91RS
GA
Not your fault. I was trying to wait it out a little anyway so he might be willing to negotiate. He knew it was a rare color but blue usually doesn’t sell that well which is why they’re rare; however, many used buyers aren’t very concerned with particular colors especially in the current market. It is what it is. We don’t need it desperately (yet) and the wife says she wants to keep her SWB Yukon. I really didn't want AWD and I would have been starting over with another restoration.
That's where I bought my truck from in 2017, think they were under a different name then.
Well, you could always pull the differential, swap out the hubs and convert the rest to RWD. Or convert to true 4x4.
91RS
GA
Trust me, I definitely considered converting it to 2WD to get the Xenon Blue. I'm tired of projects so that made the AWD two negatives instead of just one! Since I'm a perfectionist, I would have also wanted to replace the rear differential with the 2WD 14 bolt so that would increase the cost quite a bit. I could tell it needed some normal Escalade things but I could also tell it wasn't garage kept (not common since the LWB doesn't fit in most garages) and the mag ride was deleted so just more cost to get it up to my standards. In saying that I probably would have gone and looked at it before they had the pictures up and likely bought it if it wasn't rusty and the paint was all original because of the color if it had been a 2WD.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
How is this done without throwing the computer into a frenzy? Just curious. Can the front shaft/diff be removed and just run with the same trans and transfer case?
I know you know more about this stuff than I do! I get it, I'm kinda antsy to get all the projects done on my truck too. I bought a 14-bolt for it but have no immediate plans to install it, it was dirt cheap from LKQ though and couldn't resist.
Well, I guess you could even take the half shafts out, replace the hubs, or take the half shafts apart and leave the hubs and everything else hooked up. But you'd be up the creek when the computer shifts more power up front! I'd be more inclined to program the modules for RWD operation and such or convert to 4x4.
91RS
GA
The transfer case in the GMT 800 and 900 AWD is, to put it simply, a clutch driven setup that isn't selectable (there is no encoder motor). There may be an output shaft speed sensor or something but I can't remember 100%. I never researched it thoroughly but I know you cannot just remove the axles or just the front differential or just the front drive shaft or it will destroy the transfer case. You would have to do it all or not at all. My guess would be it would involve changing the hubs to 2WD units, deleting the front differential and axles, deleting the transfer case and either changing the entire transmission to a 2WD unit or gutting it and changing the output shaft and extension housing to 2WD parts, and then getting a 2WD rear drive shaft. I'm not sure if changing the 10 bolt axle to the 2WD 14 bolt would be required or not. My "worry" would be that the length between the pinion flange and the output shaft might not be the same since the 10 bolt is a smaller unit and also that the u-joint might be smaller on the 10 bolt. If those are the case a custom drive shaft would be needed but I'd guess it could cost similar to buying a used 14 bolt from a salvage yard. I've seen them for $600 before from sub-100k mile trucks. I almost bought one for my Yukon because of the price (it whines under load at speed but any GMT-800 owner knows that isn't necessarily an indicator of a problem).
14-bolts in 900s bolt right up, same u-joints. Same driveshaft according to @randeez
Why would the transfer case destroy itself if the front driveshaft was out? I ask because I have watched a video where Precision Transmission pulled the front axle out of a customer's 4x4, took apart his half-shafts and put the splined end back in the hubs to keep them from falling apart and sent the customer on his way. He was coming back shortly for overhaul.
randeez
south florida
on my truck conversion ujoint wasnt needed, the 10bolt in my awd behind a 6.2 already used a 1350 joint, outside of that i dont know. i used the brake line off my 10bolt and just had to bend it around the pumpkin a little bit to fit nice.
the awd transfer case in a 900 (BW4485) if you pull the front shaft out, just isnt going to do anything - its going to drive the output with the least amount of resistance and if theres no front shaft its just going to spin the output. i imagine at a certain point it may drive the truck but not usable.
the 800s, an autotrak or np149 case may be able to drive but the same scenario - its going to think the front axle has zero traction and is going to engage the clutch or viscous coupler the entire time, heat up, may last a few drives but wear it out pretty quick
actual selectable 4x4 transfer cases should be fine if you leave them in 2wd, either years
91RS
GA
Ideally I won’t be buying an AWD so hopefully none of this will matter to me. The only way I would consider the AWD is if it was another Xenon Blue (I would also be fine with Sapphire Blue) Escalade with a black interior otherwise in nice shape.
Came across this today:
91RS
GA
Ok, so about like I was thinking. I knew it was possible because the Trailblazer SS guys have been doing it for years. I still would rather not have to do it but the option is there. The Xenon blue is a one year only color for 2012. The Sapphire Blue is one year only for 2013. Both my Escalade and Yukon literally only have a couple of things left to be "done" and the thought of starting over just made my stomach turn. Even if that Escalade had been in excellent condition, there would still be things to do. It definitely needed paint correction and since I had at least 20 hours in buffing my SWB Escalade, I know a LWB would take even longer. One thing I know that would have cost me a fortune is a clear bra if the paint on the front end were in good shape and the headlights not faded. My Yukon is about to turn 190k and the bumper isn't in terrible shape but it also isn't good enough to be clear bra worthy. Plus, I would also have AFM again and it would have to be deleted again eventually. I only had my Yukon 6 months before it started acting up.
Drewphil
