Just Fishing
Can't fix stupid
Utah
Mine is quiet when oil is cold. Only gets noisy after the oil is fully warm and thin. IIRC I have 10-30 in it. Could be 5-30. I really can’t remember
seems to go away above 3800 rpm. Probably because everything else it making more noise lol
I pulled one of my rockers and found a clear mark from the rollers on the valve tip.
just slightly inboard!
meaning my pushrods were totally too short by just a tad. :waytogo:
Just Fishing
Can't fix stupid
Utah
Ok so I pulled the battery cable off for 20 min, grounded it. Hooked it back up. Now the window is working fine????
I was just thinking that!
I had an issue with the heated seat switch on the driver side, i was about to order a new switch.
then i took the battery off for a minute, and it's been good ever since.
Just Fishing
Can't fix stupid
Utah
You can also blacken the valve stem tips with a sharpie and turn the motor over a couple times and look at the wear pattern
Step i missed when i went with the AFR heads!
Made me feel better about making the pita switch to the longer pushrod.
I'm 48% done now.
And those spacers are sorta a pita to center perfectly.
I'm sure i'll find some clearance issues when putting the plastic cover back on. :jester:
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Now it stopped working again. LOL. Definitely need a new switch.
89Suburban
SE PA
I'm 48% done now.
Your filler tube looks so tight and solid. So jelly.
89Suburban
SE PA
Did you use a pencil eraser on the contacts? It works great. James @swathdiver can probably hook you up with a link to a Tech2.
I'll try the eraser tomorrow. Can't hurt. But I find it extremely discerning none of the 3 functions on that certain switch work but the rest are perfectly fine. My gut is telling me whatever relay's that are built into the circuit board for that function on that certain window position are beat. Or whatever circuitry thingamajigs control it. You can hear a distinct "clicking relay" sound when it decides to work on that side in the switch. You can hear it from the pass door switch too no problem.
89Suburban
SE PA
I think this is correct if pulled from a truck with similar options.
I'd be happy just to have a working drivers side window and not the rest, or the door locks or mirrors for that matter. If I could plug and play a new unit just to have that one working to get me by for now i'd be so relieved.
I DO!!! Please report back! Do you have one locking nub in your hole or 2?
1 locking nub. And the new filler tube sucks just like the old one. It rocks back and forth if you wiggle it. These need to lock on 2 sides. Is there an updated rocket cover/ filler tube combo for that side? BTW check out that awesome rocker! I never get to see those works of art.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I thought that's what this one was. What's the difference? My Denali one has retractable, pivoting covers that close to make an unbroken expanse of fake wood. It looks okay. But the doors take up so much space that there isn't enough room to even put my sunglasses in it. This one is far more useful, and only slightly less attractive. That's a compromise I'm willing to make.
I have the same one with the little doors in my LTZ
Just Fishing
Can't fix stupid
Utah
What extra o-ring did you use?
Found one that fit perfectly at the top. :waytogo:
scottd
