Yeah I've got stock injectors
I found a great deal on them and paid like $50 or something for all 8 from AC Delco. Should have bought the big 8 liter injectors though *sigh*.
I can definitely hear the lifters. Not sure if my microphone can pick it up. Sounds like a sewing machine haha And DAMN does it have a nice scream once I rev to 4500ish, however, trying to not do that tooooo much till it's broken in a bit more haha
Right now my baseline is the 5.3L tune that was in the computer. I'm running off the MAF only though. Getting the MAF sensor calibrated per Goat Rope Garage Tutorials. I think spark is all messed up though. It isn't too powerful down low but gets big kick in the pants as it takes off around 3000 RPM.
I went under general engine settings and updated the engine to 6.0L with .75L per cylinder. Interestingly that bumped up the VE table a bit so not sure if that will be enough to get me in the ball park for speed density tuning or if I'll have to copy the VE table from an LQ9. I'll have to find out. I don't think MAF only tune I'm running right now uses the VE tables but I'm a nubie so possibly wrong.
That was knock that triggered computer to pull timing. It wasn't registering right in the waveform graph. I switched the variable to another and it displayed the knock count. Learning as I'm going, just hate to see knock as well I think that's was breaks engines.
What temp do you run your stuff at? I have a 160 thermostat in my Corvette. You think is a good idea for the truck too? This engine REALLY puts off the heat. I almost wonder if it needs a larger radiator too. Although maybe possible heat is from me disabling the stuff to cool the catalytic converters in the tune too. not sure?
Learning lots. Really exciting! It has soooo much power I almost wonder if I'm stuck in a low gear or have 4 low on haha. Transmission doesn't go past 160F but it shifts weird, like not crisp but hard. I should have checked input shaft play before I put the motor back in. Hopefully lives till I can build the new one.
