DaveLaz
- Joined
- Feb 11, 2020
- Posts
- 36
- Reaction score
- 29
Hi guys, I lowered my 2006 Yukon SLT 4WD on a crown suspension 2/4 kit that included spindles, rear coils, and shock extenders. I also installed DJM rear trailing arm relocators, proper sway bar end links, and belltech 9513 street performance shocks. When tearing it down I basically had to cut everything out so I ended up also replacing with new LCA’s, UCA’s (with camber adjustment capability) inner/outer tie rod ends, and sway bar end links. Here’s been my experience so far....
At first honestly it felt decent. Some clunks and noises here and there but I figured after settling and getting an alignment it would be better. Also the front wasn’t sitting low enough and I was still on OEM shocks so I figured it would get better after the new shocks came in and I wanted to add lowering keys.
Installed the shocks and I didn’t feel much of a difference but whatever. Got an alignment and it solved a little bit of clunking but the most noticeable one was by the driver side front wheel when taking off from a light.
Had a shop install my keys since I couldn’t get them out. Also had them install new crossmember bushings since I noticed those were shot. $700 in labor plus parts later...the clunk and horrible ride still existed. I ended up having to install one of the OEM keys back into the driver side because with the torsion bolt cranked all the way up, it still sat too low on that side.
This is where I am currently. After MULTIPLE times of lifting the truck, loosening all load points, sitting the truck down and re-torquing them to be sure I’m not missing anything, I’m still having this issue.
Notable mention, the ride is significantly better when first driving after lifting it because it hasn’t settled back down fully. After driving for about 5 miles it settles back down, ride is extremely rough, and that clunk when taking off comes right back in full force.
Guys I seriously need like an open forum of questions, ideas, places where I can drive the truck off a bridge etc.... TIA!
