2010 Tahoe LTZ lift kit
Dustye36
I have a friend removing a lift from his 2007 Silverado, single cab 1500. Will the lift or any part of it fit my 2010 Tahoe LTZ? The Tahoe does have air ride. He’s offered it to me dirt cheap and I’m just wondering if anything interchanges. I didn’t find anything with search so I apologize if there’s a thread that fits what I’m asking.
If his Silverado is a NNBS and not the "Classic" early '07 body style, then the front lift components should work. Regardless of year, the rear is useless to you except maybe for the shocks, if they're longer for the lift. The trucks have a leaf-sprung rear suspension, the SUVs have a coil-sprung, multi-link rear suspension.
87carl
What kind and size lift is it?
D
Dustye36
Thank you.
Dustin Jackson
@Dustye36 Depending on the exact kit it may not be a good idea to install a used lift kit. The 3.5 inch kit is pretty cheap just buy it new
Dustin Jackson
Is it the knuckle or control arm 3.5? I have the 3.5 knuckle lift for 07-14 gm trucks from rough country in the front of mine
@87carl Can I see pictures of the front suspension? I'm curious of how the knuckle looks and the suspension angles.
87carl
I haven't had time to put cv axles back in I pulled them and differential out when I was doing timing chain so I could get oil pan out. I was waiting till I changed alignment cams to put them back in. This is with it slightly turned toward passenger side
scottd
