Aftermarket wheels
DWSmoot
Charleston, SC
So, the eBay seller I got my wheels from messaged me to tell me that there was an inventory glitch and that my wheels aren’t available and I can select something else or get a refund. What are the details on your wheels and did they require spacers?
Thanks in advance!
George
These are the wheels I purchased. Apparently not showing up as available now. No issues with fit.
George And
Thank you so much. 22x9 + 24 right.
I think I have found them from another vendor. I’d gladly go with something that has a confirmed no issue fit.
Thanks again! My truck may end up looking awfully similar to yours, although I don’t have the z71 nose.
Take care,
George
DWSmoot
Charleston, SC
Take care,
George
Glad to help. Yes 22x9 +24 offset. Me sure you confirm with seller they will fit the 2021 Tahoe.
George And
Think you could get a 305/45/22 on there. Your size is slightly bigger than stock but tire selection is very limited... everyone either has 285/45 or 305/45 available. 285/45 is smaller and wlll fit. 305/45 is the exact stock diameter but an inch wider....
Any chance you could take pics of your clearances? I think the limits will be the upper ball joint to inside of tire and the fender liners at full lock.
BTSRT
You want a 10" wide wheel. 9.5" minimum.
George And
So go with the 285/50?
The problem is that at this point aftermarket wheels are almost impossible bc of the drastically different offset and brake caliper clearance (I don’t want to run spacers) the only thing that seems to fit natively is the 19+ Silverado wheels, which are 22x9. + 24. Same exact setup as the new Tahoe.
BTSRT
Your stuck on a 22" wheel and not a 24" wheel?
George And
Will these wheels clear the 2021 brakes is the million dollar question no one seems to be able to answer. It seems like a lot of folks have ended up having to use spacers for clearance. I know ppl say they are ok but they scare me. Especially small spacers that don’t bolt to the hub. And it’s not a pickup wheel poke isn’t what I’m after. I just traded my lifted Silverado for the Tahoe. It looked badass but the lift / wheel tire setup was constant issues. I broke a ball joint at 17k miles, ended up with new control arms, it broke a camber adjuster and had to come apart yet again, and it never did want to hold the alignment correctly. Plus it rubbed at full lock in reverse because I wasn’t willing to take a sledgehammer and sawzall to a brand new truck to NorCal mod it.
That’s why I’m trying to be conservative and go with something that fits without issues.
BTSRT
Contact factory reproductions. Honestly, I dont think you'll have a problem. I could clear a football with my 26's. Front brake setup is the same as prior generation. Rears are different due independent rear and electronic brake
Chad Miller
Hi, I'm new here. Hoping this is an appropriate place for this post. . . .
I want a more aggressive looking wheel / tire set up for my 2018 Tahoe. I do not want to lift, level, or install spacers. I'm looking at 20x9 wheels with a General Grabber 275/55R20 A/TX tire. Tire Rack is telling me this set up will require fender modifications or lift kit for proper clearance.
I'm hesitant to order my set up only to have my installer tell me it won't fit.
Any insight, guidance, resources, etc is greatly appreciated.
Thank you!
Greg Kulbick
Tallahassee, FL
That's the stock tire size on your vehicle. You'll be fine unless the wheels you're looking at have some crazy backspacing.
BTSRT
24"+ with the correct offset is a must on 2021's.
Maindog
I picked up a set of 4 from eBay for less than $40 bucks. GM Part # 84991144. My setup was from a local shop here in Sacramento. Big Tire & Wheels
bigskyR35
Montana
Just ordered some Koko Kuture Kapan's in a 24x10. Plan to mount on a 285/40/24 which is a 0.2" larger diameter than stock to help fill some fender well. Then eventually drop it a bit to close the fender gap.
AllyNJ
