4 Piston Big Brake Upgrade from 2019-20
fasteddy
fasteddy
Well See,
Its always a test in the aftermarket world.
I'll do SS lines and high friction pads to compensate for any pedal/boost issues. Thats just risk mitigation, not a known issue.
BTW, I've done Wilwood 6P calipers on another tahoe. You have to grind on the spindle for about 30 mins per side to get that braket to fit.
Not exactly bolt on. And they sent me a scored new rotor that had to be returned. I had to PAY for a new one until they got their NEW core back.
Their customer service sucks too.
R&D is sometimes painful but always exciting! Its part of the resto fun. I enjoy it.
Success favors the positive thinker.
I haven't seen any silverado conversion brake failures on youtube, so I think its worth a try.
My current brakes suck so anything has to be an improvement.
Ah, I think we're all in agreement that Silverado's are not race cars. Obviously, the fellow who did exactly what you stated couldn't even get his truck to screech to a halt because his system was a total mismatch of components. My comments were to those who might blindly choose to follow the somewhat misguided internet "how to" video. Some, (many?) forum members may not be aware that upgrading your brake system is not plug n' play like plugging in the USB of a different mouse on your computer. To be generous, it would be surprising if anyone could successfully simply change from their two piston slide caliper system to a 4 or 6 pot system in the front and a 4 pot rear without a master cylinder modification and not have deleterious effects on their braking system. And you have it on good authority I assume, what brake modifications that General Motors' attorneys support...
I have Wilwood’s massive 6 piston 16” fronts and 4 piston 14.25” rears on my 02 Denali and my 08 Silverado and believe me they work awesome. ABS works as designed. Relax, this mod will work great.
ThisIsLivin
What do you mean my Denali isn't a race car? My Denali drifts through corners better than most cars I've owned. I put it in tow mode and it keeps the trans in the perfect gear for hot rodding, of course after a few tuning mods. It steers with the gas perfectly. Granted it's nowhere near my Callaway Corvette, but it's still fun and keeps my skills sharp.
01subCT
waterbury ct
I just purchased all my parts.but im waiting on my rotors cause if I'm running these pretty calipers wanna have nice rotors to.running 24s on my suburban so you can see them pretty good
Calipers from gmpartsgiant.com 79.00 each plus shipping I think
I went with raybestos pads half the price if gm and by there site suppose to be alittle better.
Raybestos element 3 hybrids. 42.00 of ebay!
And for the cross drilled rotors I got powerstops.those were really tough to find.got them from carid.says they won't ship till April 30.they were 155 but the hammered me 40.00 for shipping on top.
I already have the 07 upgrade so very curious to see the difference!
corvette744
2004 Z-71
Northern illinois
This is the upgrade i want to hear about.07 upgrade already done now let us no how much better or worse it is-honest test.
the_tool_man
Upstate South Carolina
I too am anxiously awaiting test results. But it needs to be a proper test...
Remember that for a single stopping event for a modern vehicle with a properly functioning braking system (ABS or not), the limit of braking is not the diameter of the disc, or the pad area. It is the tire contact patch area and the maximum static friction it can generate. If the brakes are powerful enough to lock the wheels, the only way to improve braking (again, in the case of a single stop) is to improve tire traction. All that to say, a single stop isn't likely to tell you anything about brake performance improvement unless your system had an issue preventing lockup before the swap.
Bigger brakes are beneficial because if you make multiple stops in rapid succession, or have to brake a very large load, such as when towing, you get better heat dissipation. This reduces the likelihood that the brakes will fade and lose effectiveness.
So, a proper test needs to be multiple stops in close succession to see how long it takes for stopping distance to increase due to fading. For me, a good result in such a test would convince me to upgrade, since I sometimes tow heavy, and have to contend with mile-long steep descents on occasion.
91RS
GA
Except that a full-on ABS stop is maybe 1% of what brakes get used for over their life. That is just like only talking about max HP for a camshaft, it only makes that max HP at WOT at 6k RPM. The other 99% is what matters, what does that torque curve look like? Braking is improved at all speeds and modulation with bigger brakes.
the_tool_man
A full-on stop is a quick test method. I never said it represented real-world common usage.
When you say "improved", what exactly do you mean? Are you talking about brake effectiveness for a given amount of brake pedal force?
oh05ext
Ohio
im interested in the outcome of this. id love a 13.5" front rotor
Noggles
I think there is a lot of overthinking going on in this thread. A larger rotor and more clamping force with everything else being the same and adequate, will result in shorter stopping distances. I upgraded the 2 piston calipers and tiny rotors on my 02 trans am to the 4 piston brembos off the base c7 and the stopping ability, distance and repeatability improved substantially. A properly functioning, properly bled system will function fine with the increased piston surface area but most people won't take care of their brake system and then complain about spongy brake pedal feel.
fasteddy
fasteddy
Me too!
Just as an FYI the pad area of the 2020 silverado brake pad is approximately 15 sqin
I don't have the exact area as i can't find it.
Here are the dimensions of the pad.
Its not perfectly square, so I adjusted the approx area down by 1 sqin, could be more....lazy math.
Length 5.47” (138.78mm)
Height 2.95” (74.92mm)
Thickness .708 (17.9mm)
Here's the PIC
The wilwood 6p pad area with the 14"/16" rotor is 11.1/12.69
Which means the silverado pad has at least a 20% increase in friction, which is really good!
The issue that I've heard some folks are concerned about is clamping force, the ability to apply that friction....and create stopping power.
And that has to be tested.....we'll see.
My current brakes suck and I hate them. I have to give up sooooo much space from the vehicle in front of me that people are always cutting me off....LOL
AN292
I am shocked at how huge these are. Lmao. I've never had big brakes before so maybe I'm just new to it but they're about 11 inches across and heavy as hell. Looks like 10 inches but its the angle of the camera.
Between 10-15 pounds each.
AN292
01subCT
waterbury ct
I don't want red like they all do.but my truck is charcoal I was wondering what a bronx color mite look like
fasteddy
fasteddy
Famous last words.....not yet.....
You have to put them on the vehicle unless you're just going to hang them up in the living room...lol
Can you see if they fit on the back and get back? Thanks, you're truly a master mechanic.
Weight?
I know.....more weight with
calipers
rotors
falken wildpeaks @64lbs
All unsprung weight......so sad...my poor wheel hubs are all stressed.
AN292
Anyone know if they have speed bleeders for the 2020 calipers?
CKendrick
