Looking for Advice on Replacement Shock/Spring Options
Hi Folks,
As I was installing my new Hellwig sway bar on the rear of my 07 Yukon XL Denali, I noticed that I have a leaking rear shock. So, I need to replace the rear shocks.
When I purchased this new-to-me truck, the OEM rear air ride had already been replaced with cheap coil-over shocks. I currently have OEM coil springs, which look 'relatively' new, and I verified that they are in fact the OEM springs meant to be used with the air ride shocks, by looking at the part number tag (25783732) on one of them.
My understanding is that when the air ride is removed on these trucks, the coil springs need to be replaced with stronger springs, as the springs supplied with the air ride are weaker, as the air ride shock combo takes part of the task of supporting the weight of the truck. Is this true?
As I see it, I have 3 options available.
1. Restore the original air ride system by purchasing air ride shocks and reconnecting the compressor and all related accessories. My current feeling is that I do not want to pursue this option, as I do not know the current condition of the compressor and all or the related accessories. I do not want to go down a monetary rat hole.
2. Replace the existing coil-over shocks with a decent quality coil-over shocks, if one can be found for this truck.
3. Replace the existing coil springs with stronger coil springs, and replace the existing cheap coil-over shocks with decent quality standalone shocks.
I'd like to hear from all of you with your thoughts and perspectives. Perhaps, there are additional options beyond the three above, that I have not yet identified. In your responses, if you have specific brand/part number recommendations on the coil springs and shocks that I should be considering, I'd certainly like to see them.
Thanks in advance.
Bill 1960
Testing the Limits
I’d do option 3 myself. Not a fan of coilover shocks for the rear. I believe your best ride quality will be stock springs and a quality shock.
I do have a bias toward sticking with OEM engineered solutions, as I believe aftermarket is more often than not inferior. (Says the guy with a 6” lift LOL)
@PNW VietVet @Tonyrodz @Doubeleive @Miami-Dade @kbuskill @Fless @Bill 1960 @Jason in DLH @swathdiver @soulsea @Dantheman1540
Hi folks, Any thoughts/suggestions/recommendations?
If not, are there any other folks here on the Forum that may be able to help out, that you could "@" to this thread?
Thanks.
there are some springs on rockauto that are like oem +1" (not oem) if you look at the spring options on rockauto you will see what I mean otherwise I can look later and link to them
Jason in DLH
Cheeseburger and Fries
MN
Hi Folks,
Thanks in advance.
I’d say option 3 as well. When I retired my AutoRide I kept the same coil springs and thought it rode great. The rear shocks needed to be replaced shortly thereafter and I went with Rancho RS5000’s and it still feels like an OEM ride in my opinion (I do have 2” coil spacers, so I went with a slightly longer shock).
You can always change to a stiffer spring in the future if the original doesn’t seem right, but I think it’ll work out great with the original.
kbuskill
NE. FL.
All of this is subjective.
Are you happy with the current ride height and quality?
One option you didn't mention would be to just install a set of old school air shocks, which would operate exactly like the factory auto leveling shocks, minus the autoride dampening (which you currently don't have any way) and the automatic leveling.
Instead of hooking up the air shocks to the factory compressor you could just install a shrader valve somewhere to manually inflate or deflate the shocks as needed, like if you hooked up to a trailer or loaded up the back of the truck heavy.
The factory auto level springs will sag a little without the air shocks to back them up.
The air shocks I mentioned would definitely be the most economical way to go (less than $100) but not necessarily the best way, but it really all depends on how you use the truck and what ride characteristics are important to you.
@Joseph Garcia, I don't know enough about the 07 and newer springs to be of help on this.
After reading what @Bill 1960 said, I have to agree with option #3. The simpler the better and I have never been a fan of coil over shocks.
I also don't know about the 900 platform--sorry, but if it was me I'd also go with option #3. Keeping it as simple as possible.
Miami-Dade
Moderator Supporting Member
Hi Folks,
Thanks in advance.
If this was my 2007 Denali I would do option 3. Option 1 would definitely be a monetary rat hole IMHO.
Hi Folks,
Thanks in advance.
If I had a Denali I would maintain what it came with, Option 1.
My truck has the basic suspension and these are the part numbers if you decide on option 3: Rear Springs are 25783733/45H2164 Rear Shocks are: 25871227/540-435
Thank you so much for your replies and perspective, folks. VERY much appreciated. This is what this Forum is all about, and what makes it a HUGE success.
After considering all of your input, I am currently leaning toward option 3.
Thanks again!! I'll report back when I make a change to the suspension.
I looked at RA, after your post, and I'm not sure which OEM +1 coils you are referring to. When it is convenient for you, can you post a part number that you are referring to?
Thanks in advance.
JGreene
When I did my conversion on our 2007 Denali I went with Moog springs and seats from RockAuto; totaled $200. Springs were part #81069 and seats were part #K160072. I also replaced the shocks with Bilstein 5100s from 4Wheel Parts (part #24-187237); totaled $400.
Thanks in advance.
I went and looked again at a few different years and models and it looks like they no longer have them and now have added a whole bunch of oem and moog :shrug: sorry man.
ThisIsLivin
I replaced my magnetic ride struts and shocks on my 2015 Yukon Denali with Arnott. They use a Eilbach shock with the air leveling and the resistor to fool the computer. I love them, they are definitely better than the OEM and lifetime guarantee.
Butch Pink
Manchester, MI
Hi Folks,
Thanks in advance.
We pulled the rear air shocks on my 2007 Yukon XL Denali for Rancho RS5000 and Moog HD springs (Shock and springs are separate on my truck). I purchased the electronic bypass modules on eBay for $25 for 4. We did replace the bushings on the stock sway bar with Moog Polyurethane bushings. No issues in the back now at all.
bobsburban
I went with the 1250 lb Moog rear springs (pretty sure they are the Z71 spec coils noted above) and Bilstein 5100s all around. Rear was lifted 1.5 - 2", so I set the front spring perch up one notch on the front shock body. Ride is wife-approved and much improved over the blown out air ride shocks. Extra ground clearance helps with some off-road tires. I'll get the stiffer front springs if I ever hang a winch or heavy bumper on the front of the truck but saw no real need for them at this point.
Highly recommended.
Thank you for all of your additional replies and your related experiences and recommendations. VERY much appreciated. I'll be making a final decision soon on this.
Thanks again.
Drewphil
