They’re really not that bad if you pull the trans mount and lower the tail down, then you can see them. Use a 3-4’ extension on your ratchet.Glad you got it out!
Yes, **** those upper bell housing bolts. That was the biggest ***** of the whole process. I fought with them from the bottom, finally succeeded. Mine is going back in with the intake off the engine so I can get at them from the top.
