Autoride suspension help
B
BH1989
Well once again it has been a while since I updated, but all seems to work fine on my suspension. I had a buddy with a snap on scan tool look at the autoride system and everything seems to be working as it should and no codes in the system. The compressor still doesn't start up every time I start the truck, but when adding weight it does lift up and when taking weight out, it does exhaust to a normal pressure.
I did speak with my dealer as well and was told there would be instances when the compressor wont run on start up.
Glad it’s all good. Mine doesn’t run every startup either even if it’s sat for overnight.
St. Louis
Yup, I just replaced my compressor yesterday and today I noticed the compressor didn't kick on evertime I started it today. I also felt the air bladders before getting in and they were still firm after sitting overnight.
St. Louis
They don't take the old pumps for cores like the shocks do they?
St. Louis
@Doubeleive @George B
Which line from the GM line kit did you use for the driver's side replacement?
The kit comes with 3 lines. The shortest is clear with 90* ends and is longer than the stock one that we're replacing because it's tighter now with Arnott's lower connector. The other 2 lines are black with straight boots on one end and 90* on the other, and the shortest of those two is about 2' long
The clear one goes from the comp to the T. So it must have been the longer of the 2 black ones, which is meant for the passenger side.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Used the shorter clear one on the driver side.
George B
¯\_(ツ)_/¯
Moving this here since this thread is a good source of info.
Ugh! C0585
  • Checked the plug > Good
  • Checked the resistance of the shock > Open
  • Plugged it back in and drove to work > No service suspension message anymore.
I suspect a faulty shock.
Going to check the code again when I get home.
2013 Suburban LTZ, 5.3, 3.42
Or perhaps a faulty connection. Whenever I remove the connector from those, I use electrical contact cleaner before I put it back on. Otherwise I get the same error.
But what about the fact the shock tested open with no resistance? Should be around 3.5 Ohms right?
George B
¯\_(ツ)_/¯
Chasing my C0585 for the left rear. I measured the resistance of the right side and got 2.5 ohms. The left side is open for all practical purposes and requires me to be in the 20k or 200k range to see any resistance. Replacement shock on order from RA.
George B
¯\_(ツ)_/¯
Did a little troubleshooting tonight. When I clear the code it sets again immediately. Since the right side shock measured 2.5 ohms I found a light bulb that measured the same. I plugged the bulb into the connector for the left side and used my tech2 to clear the code and then command the actuator. The light comes on and the code doesn’t set.
New shock is on the way.
7815F974-FDFF-4341-8AC6-36E29DBE0055.jpeg 6931F087-551D-4D8E-84BF-4A5EAB524343.jpeg
View attachment 278417 View attachment 278418
*light bulb goes off in George’s head*
Joeltz
Very good info , my 2015 LTZ @ 100,500
never hear the pump run…. Believe it’s both rear shocks and the pump, and one question on the pump is what wire connectors do I.. hot wire just to see if the pump runs…. Good forum here thanks
BadDaddy2003
