meh, it is what it is
Going to install this tomorrow but wanted to know what I can tap into in the side fuse panel so I can hard wire it. Any suggestions?
if it has a option for 12v hardwire then you can just tape into the footwell kickpanel down by your left foot area, or use a fuse adapter and tap into one in your photo.
osidesurfer365
San Diego
Do you want constant power or switched? Switched is easy, right at your rearview mirror.
Recommends constant power. Because there are small fuses attached in the wiring I can’t tap into the mirror and tuck the fuses in the headliner.
St. Louis
You can get all you need, (ground, constant power, accessory power, or RAP) from the upfitter box just to the left of the brake pedal.
osidesurfer365
San Diego
Good to know. You by any chance have a pic letting me know which ones to tap into?
Sparksalot
Bastrop County, Texas
What took so long to replace the strut on the left side?
First was figuring out how to get it apart. Then I discovered, after the strut was assembled and under tension, that the 3 studs on top are not symmetrically placed. That caused about 45 minutes of trying to lever the bottom end into place and get the bolts started.
there’s definitely a learning curve!
wjburken
Eastern Iowa
I was wondering if it was gaining experience on the first side. I ask because I am likely going to be doing this on the wife’s Yukon soon.
brice715
