the problem with the inner seals on the nnbs is the bottom part gets all torn up from getting in & out, never had that problem on my nbs, both driver and passenger side were tore up already when I bought mine and every one I looked at were as well, it doesn't seem to have gotten any worse since I have owned it and I don't think I ever step there so it must happen from short people :shrug:
Vertically challenged--
08z71bgm
Long Island, NY
looks easy enough I think this seal has little plastic clips, mine has not arrived yet but I was looking thru the 11,000+ pages of the service manual and saw it, lol
Don’t over complicate it. Super easy to swap. Took me less than 7 mins start to finish. A1 1A whatever auto did a YouTube video on it. It’s the most simplest thing I done on the truck yet.
08z71bgm
Long Island, NY
Why did you use the “wrinkle plus” vs. the standard VHT paint? Just curious if it’s because that’s what you had laying around, or if it’s something specific for alum/oxi. I’ve used VHT on the manifolds/headers and calipers before but never tried their wrinkle plus line.
It might be worth trying some of the 3M stuff. It definitely won’t cause any tear issues with future repairs.
That is completely unnecessary for the door seal! If you get the gm one it fits just fine. The only time I needed to use this was on the windshield seal for the vert top on the c4
I am still waiting for mine to get here it left texas and skipped california (where i live) and wound up in oregon, now it has a shipping exception and a delivery date for jan 10th when it is less than 5 hours from me, wtf
St. Louis
Shit, I had a package sitting at the St. Louis hub (10mins from my house) from the 11th of December till the 21st. Original delivery was scheduled for the 12th. Had another here at the local hub on the 12th and not delivered till the 23rd
here is one I shipped nov 23rd, usps still claims it's simply delayed
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
And while installing the valve covers yesterday.
I decided i might as well clean them up a bit.
No point to install dirty parts...
I thought for a moment about giving them a high polish, but went for a light brushed look using Fine grit 3M Crossbuffs...
Top picture you can see my AC flush tool that i used to prime the oil system... :D
I also replaced the oil fill tube, cap, oil level dipstick tube, and dipstick.
Went to remove the Oil Fill cap and noticed it's a one time use, lock tab breaks off! :D
And the dipstick would not remove for me when pulling the heads, it was a bit tweaked.
Found the local dealership had everything i needed in stock.
So i mangled the F out of the dipstick tube to get it out.
:greenchainsaw:
New one slid in after being well lubed. :cool:
What oil fill tube and cap did you go with?
89Suburban
SE PA
For some reason this dashtop panel keeps popping up. Still have the little drummer boy noise too under the dash when it’s cold.
Just Fishing
Can't fix stupid
Utah
just started the hoe with everything connected, getting a C0561 error.
"ABS invalid data"
Otherwise it seems good.
I did get some messages about stabalitrack...
Might need to remove some other AFM related things in the tune...
I still had sensor errors enabled, so i'll try killing those first.
Jason in DLH
Cheeseburger and Fries
MN
Wife’s not gonna be happy...painted in the garage again. :rolleyes:
Was going to remove side panel thing, but decided too much work, so painted right on over it...
Still undecided if I should wet sand and polish the flares or rubberize them to match.
Always wanted a two tone. :D But seriously...wife’s gonna be mad.
dizhai
