Tech 2 Purchase
Just thought I would post this here...
https://www.chinacardiags.com/whole...or-gm-saab-opel-suzuki-isuzu-holden-1011.html
They have the Tech 2 with a case and all accessories for $289 with "Free" shipping.
They also have the Tech 2 with all the accessories but without a case for $215 BUT they charge $68 for shipping.
I opted to pay the extra $6 and get the case and the "Free" shipping.
Waiting to see how long it takes to receive it.
Anyway, I thought it was a pretty decent deal so I figured I would share.
finally bit the bullet:cool:
kbuskill
NE. FL.
Yeah, my buddy that has the 2001 Suburban that is having issues was the deciding factor.
I have wanted one for a long time but never had the NEED for one. My buddy is supposed to split the cost with me to figure out what is wrong with his truck so I figured it was a win win.
Just Fishing
Can't fix stupid
Utah
Tech2 is pretty handy. :cheers:
I have an old pelican case that i bought as a teenager from a thrift shop ($5 iirc).
Been trying for years to find a good use for it.
I finally have it, a tech2 case!
Now i just need new foam for it... :D
BatsTDK
Orange County, CA
My vxdiag is due to arrive today. Not too hopefull but will see what happens.
Good luck. I got mine a couple weeks ago. It's finicky for sure. I'm an IT technician and even I had trouble getting the software to work. DVD came with corrupt files.
BatsTDK
Orange County, CA
I did. I ended up having to find some of the software online and googling the errors I was getting. Now I can never get rid of the laptop I installed it on because I don’t dare attempt it again lol. I guess it’s a shop computer now.
Follow the instructions mostly, but there was a step where the Tech2 emulator wasn’t seeing the connector attached. I ended up downloading a separate program that finally got it up and running where the Tech2 could see it.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Wont connect to our 2002 gmc
what do you mean by "wont connect" are you choosing the correct vin? if you just go down the list and try each one it will tell what vehicle it expects
if you are not getting any data on the obd port then check to see if you have power at the cigarette lighter/power port the same fuse is used for the obd communication
also the vxdiag software has to be started first and left running in the background before you open tech2win
BatsTDK
Orange County, CA
I see by his picture of that the Tech2 software is detecting the CANdi module attached so it’s at least seeing the connector.
George, are you selecting the correct product line after you pick the year? I had to google to figure out which one my Yukon was.
George B
¯\_(ツ)_/¯
So first the cable was bad out of the box. I used a different cable for an old android phone and was able to get it to connect “once” and check for DTCs and get in to look at the HVAC mode doors. I have the vxdiag running and then open the tech2win. Select 2002 and then go to GMC truck. Have menus to choose the various systems from there. Went into HVAC and saw the option for the module tests but from there it either errors that I lost connection or flashes like it keeps reloading the page.
BatsTDK
Orange County, CA
You selected “LD trk, MPV, Incomplete” right?
the cable could be a problem, if it is not pushing 5v thru very well it could potentially be a issue. I would try to find a nice thick one at the store or just get the best one they have to see if that helps. If the vehicle battery is low that could be a problem also if you are going to be doing extended testing I would hook up a charger. If none of that helps then it could be the laptop usb port is weak voltage wise and you try using a different usb port or use a powered usb hub or docking station.
if none of the above helps then you may either have a funky vxdiag or there is a problem with the lan bus on the truck.
BatsTDK
Orange County, CA
I could be wrong, but I thought I read somewhere that the emulated software has some limitations and can’t read or do certain things?
George B
¯\_(ツ)_/¯
The only reason I went with the vxdiag is because I got stuck with the laptop and couldn’t return it. I am really wanting the Tech2 clone handheld.
MonteJ
