Complete Trans Fluid Change
Bob2C
Northern VA
I have that same exact pump.
I modified the housing to flow more air, and i usually put a box fan blowing on it when running it.
I prime the pump using my power vac brake bleeder.
I also took the pump apart and found it to have a decent design for the money.
That’s a great idea to use the brake bleeder to prime. I figure it’s going g to be a while before I do it again. I put amsoil so it should last a while.
Jason in DLH
Jason in DLH
Cheeseburger and Fries
MN
Well, I received the 10 feet of 3/8” tube late last night and was able to put it down my dipstick tube to extract roughly 4 liters of fluid until it started sucking more air than fluid...
Took about 10 minutes with this small compressor (was only able to run a continuous 25-30 psi) and the Capri Tools Vacuum Bleeder (make sure to use thread seal tape on compressor fittings). A closer view of the Vacuum Bleeder...
A closer look at the hose going into the dipstick tube...
Here’s the fluid I was able to extract this method...
Next I’ll be removing the trans cooling line and starting the engine (carefully not running the pump dry)and removing more fluid before dropping the pan.
The fluid looked good. No signs of problems such as a burnt smell and although it looks completely black in the pictures there is a good pink tint to it.
Jason in DLH
Jason in DLH
MN
Alrighty...finally finished up the transmission fluid and filter change tonight on the 2007 Yukon Denali.
Hardest part of it all was removing the filter gasket. Definitely will be using the special puller next time. It was in there tight!
Here’s some general notes that might help someone: after sucking as much fluid as possible from methods above I then slightly lowered the pan enough to put the vacuum tube inside and sucked up as much fluid as possible before dropping the pan. I then used a 30” Tekton pry bar and a floor Jack to lower the exhaust...
Major flexing, but did the job...
I was then able to remove the pan without spilling fluid all over the floor. Here’s the fluid that was left after all the sucking (I must have had the vacuum line on the shallow part).
Cleaned both mating surfaces and the pan well (I had to use 1500 grit sandpaper in a few isolated areas as there was some rust buildup). Good as new!
OEM filter and gasket part number is GM 24236517
I used RPT Shift Pro Filter and Gasket part number 997709 and it matched OEM perfectly.
Jason in DLH
Jason in DLH
MN
I then used a 21 mm impact socket and tapped the new filter gasket in and used my hand to pound the filter in.
Attached the pan and torqued the pan bolts to 80 inch pounds (I’ve got the six speed) per recommended attaching sequence.
Thus far I’ve added 1 gallon of fluid using this 18” funnel as per Hayes manual and tomorrow I’ll complete the recommended fluid fill procedure.
Oh...and I didn’t need to detach the shift cable as it wasn’t in my way to remove the bolts...
Jason in DLH
Jason in DLH
MN
Turns out I only extracted 7 quarts of fluid. Perhaps I didn’t let the engine idle long enough when I had the cooling line off (was nervous of running the pump dry). Was certain I should have extracted much more.
anyways...still waiting to do a hot check. Haven’t had the tranny up to temp yet to do so.
JonnyTahoe
Minneapolis
TheEnder
Chevrolet’s have sealed transmissions? I didn’t know that, i thought they had dipsticks. Something i need to know when i look at new Tahoes i guess. I know Chrysler doesn’t have any dipsticks as they’re fully sealed german transmissions, and that’s what i’m familiar with.
wjburken
Eastern Iowa
I know GM was going to, or has moved to sealed transmissions, but the 2007-2014’s do not have a sealed transmissions.
TheEnder
Is that because of the 6L80 i think it’s called? Sorry, i’m very new to modern GM.
JonnyTahoe
Minneapolis
If you drain a small amount of old fluid into a glass jar you will see exactly how dark it is compared to the new fluid. I can see the brownish fluid on the side of your bucket which is exactly how mine was.
HACK BLOCK
NYC
would it make sense for an example I was to pump out 4qts and replace it with fresh trans fluid and drive for a couple of days and repeat till all the fluid looks good? would that get all the fluid?
Jason in DLH
Jason in DLH
MN
I don’t see why not. Although, I do think it’s important to drop the pan to change the filter and clean the magnet off and examine if you have larger shavings.
wjburken
Eastern Iowa
If you have 12 qts and you pull 4 qts out, that’s 66% old / 33% new after the first swap. After the second 4 qt swap, you’ll have 44% / 56%, then 30%/70%.
After 12 qts you’ll be at about 70% new 4 qts at a time.
If you pull 6 qts each time, two steps gets you to 75% new while using 12 qts also.
HACK BLOCK
NYC
the 4qts wasn't an exact number it was just to see if the concept of removing the old fluid and adding new would work for the transmission. I usually do that with the power steering just keep adding new and letting it run till its all good
albac
