Complete Trans Fluid Change
kbuskill
NE. FL.
This has probably been a topic of discussion time after time, but here is a good article from Popular Mechanics on how to do an ATF fluid replacement and how to remove ATF from “torque converter, clutch drums, valve body, and elsewhere” when you are replacing the ATF fluid.
https://www.popularmechanics.com/cars/how-to/a105/1272521/
This is how many of us on the forum have done the transmission service on our trucks, myself included.
The top line is the one you want to pull and hook a hose to and stick the other end in a bucket.
I used clear hose so I could see when the color of the fluid changed so that I knew all the old fluid had been removed.
I refilled with Wolf's head full synthetic Dexron VI.
Bob2C
Northern VA
What I found worked after I made a mess from the tubing coming out and pumping oil everywhere was get the adapter piece and hose. It snaps in just like the oil cooler line.
Woodblocker55
So how are you changing tranny fluid ? I was thinking suck fluid out before changing filter ?? I just changed lines I have 4 pipes from the ends .
Sent from my LGL722DL using Tapatalk
Bob2C
Northern VA
So. I originally got the oil out of the pan by using the method of tapping the lower trans line (its the one that oil will be pumped out of) on the driver side for my 18 Tahoe. Start vehicle and let trans pump bring out oil until you see air bubbles. I then dropped the pan partially, changed the filter, magnet and wiped out pan. Then put about 8 quarts back in and begin to pump again until fluid was cherry red. I suspect I got about 10 or so of the 12 qts out that way. Then just topped off to bring up to fill mark. I did some towing over the summer and just wanted to do a quick fluid exchange without going through the hassle of disconnecting the line so I picked up a pump. It worked great. It got out about 5.25 qts. The only thing is that the suction line is not long enough so I picked up clear tubing at Lowe’s. 3/8 OD. Fit over pump tubing snug. Just make sure that the bought tubing is long enough to make your connection outside of the dipstick. I did the fluid exchange on a stone cold vehicle. I put back exactly what I took out. Easy transfer.
One thing to note. The pump will need to be primed with oil before it will extract.
Suck on line until trans oil reaches past pump. Lol.
Hope this helps
Woodblocker55
Great idea .. even cold change of 5 + quarts and do more often. And like do that 3-4 times in between filter changes . Bet that make the tranny last longer .. [emoji106][emoji108]
Jason in DLH
Jason in DLH
Cheeseburger and Fries
MN
Nice work! I’ve got a 10’ hose coming that I’ll cut to length to make it to the bottom and suck the fluid out before dropping the pan. I’ll be attaching the hose to a Capri Tools Vacuum Bleeder which I originally got for bleeding brakes but have found multiple uses for it such as this:
JTRATX
For those that did the pump out of the upper hose to radiator, do you recall how much was needed for a refill?
I'm assuming that gets most of the torque converter and also most of the fluid in the pan?
Jason in DLH
Jason in DLH
MN
I’ll be doing this tonight and I’ll let you know how much I add. I have to confirm when I’m under the truck that I do indeed have the 6L80 transmission.
Bob2C
Northern VA
It’s about 5 to 5.5 qts. Once you see air bubbles you need to stop. You don’t want run pump dry. There is still a bit left in pan and a full torque converter. (About 6 qts). Now you can drop the pan without making a complete mess.
This is a great video
JTRATX
Great video! That should be a sticky video on the DIY maintenance.
Bob2C
Northern VA
Yep. That’s how I learned to do mine. I don’t know how he gets the tubing to stay in the radiator. Mine blew out and made a mess. I had to have someone hold it in. That’s why I suggest the parts above. No chance for mess.
HACK BLOCK
NYC
Hope this helps
never needed to prime my pump and I have the same one
Just Fishing
Can't fix stupid
Utah
Hope this helps
I have that same exact pump.
I modified the housing to flow more air, and i usually put a box fan blowing on it when running it.
I prime the pump using my power vac brake bleeder.
I also took the pump apart and found it to have a decent design for the money.
JasonW4141
